Results 1 to 9 of 9
    2007 Marzocchi XC 700 SL air pressure settings
    just recieved a Marzocchi Retro XC 700 SL from pricepoint.
    im having alot of fun with this fork so far, it is alot more fun/plusher than my older 1998 Z.2 BAM.
    though i am having trouble figuring out the proper air pressure settings with this fork...
    i weigh 155lbs and by looking at the recommend settings from marzocchi, i should have it set at (top/bottom) 85/115.
    it seems really stiff so i tried 60/110 which seems feels a little better.
    any ideas on what pressure settings i should have or experiences you guys have had with this fork?
    note: im riding on a trek stp softail and ride xc new england trails.
    Reputation: slowrider's Avatar
    worthless manual
    try 3 to 1 top to bottom as a starting point.
    yeah the manual is not the best.
    so when u mean 3:1.... if i have the bottom at 115, divide that by 3 correct?
    so the top would be about 38
    yes but
    Quote Originally Posted by tbone8ty
    I'm 200 lbs and I use more like 60/20. but thats on an xc700sl.
    Quote Originally Posted by slowrider
    the xc700sl is what were talking about..
    do u mean 60/120? .......60/20 you would bottom out, right?
    Nope
    I don't know whats up with the Marz set points but they turned the 130mm fork into a 25mm travel fork; I actually use 60/20 on the xc 700 sl on my 5 Spot with a 70mm stem and I've still come up with more like 123mm travel. I have a freind with the same fork on his ID and his set up is the same as mine so give it a try.Give it a try.
    i call it a kaiser blade
    marz settings are essentially arbitrary.
    just make sure that your PAR is greater than your SFA by 30 psi.
    then go with what works.
    thanks guys im gonna try different settings out this weekend
    Nov 2014
    How do you ad air on the bottom. I only can add air on the top after removing the adjustment cover.
    This is mine
    https://www.singletracks.com/bike-re...-XC-700-SL_267
