Results 1 to 2 of 2
    20 mm axle options for a 2005 Fox Vanilla 36 150mm?
    20 mm axle options for a 2005 Fox Vanilla 36 150mm? Thinking of a purchase but there is no axle. What can I use that is compatible with this shock?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dbbarney View Post
    Through axles are specific to the fork. You need to get the compatible Fox axle.
    mtbtires.com
  1. Fox talas 150mm 15mm thru axle 1.5 straight tube
    By Fparra in forum Cannondale
    Last Post: 02-15-2013, 06:26 AM
  2. 10mm offset 150mm through axle fat frame?
    By autodoctor911 in forum Fat Bikes
    Last Post: 01-25-2013, 12:43 PM
  3. crown to axle, fox float 160 @ 150mm?
    By fuenstock in forum Shocks and Suspension
    Last Post: 04-30-2012, 03:19 PM
  4. Better hub than a DT 440FR for a 150mm x12mm thru axle setup?
    By 29erchico in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-27-2011, 12:17 AM
  5. 15mm vs 20mm axle for 150mm fork
    By Ansible in forum All Mountain
    Last Post: 08-15-2011, 02:41 AM
