Results 1 to 8 of 8
    1997/8 Rock Shox Disc brakes
    I just picked up a RS disc kit for front cable actuated calipers. The disc has 3 holes for mounting instead of 6. Is there a special hub that went with these brakes?
    Any info on these brakes/hubs would be appreciated.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Yes, there was a different hub that went with the 3 bolt discs. I have a White Industries/Rock Shox hub that was given to me. I thought it would fit the Amp Research discs I had. The bolt circle diameter for the Rock Shox discs is different than the Amp Research though. I went ahead and made an adapter to run modern 6 bolt discs on the White Ind. hub but never built a wheel out of it. PM me if you are interested in the hub.
    Attached Thumbnails Attached Thumbnails 1997/8 Rock Shox Disc brakes-100_0534-small.jpg
    1997/8 Rock Shox Disc brakes-100_0535-small.jpg
    1997/8 Rock Shox Disc brakes-100_0536-small.jpg
    1997/8 Rock Shox Disc brakes-100_0537-small.jpg
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    These might work
    ASHIMA Aineon Hub
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Quote Originally Posted by Zoke2 View Post
    These might work
    ASHIMA Aineon Hub
    Those are cool and might work but I'm trying to use only period correct parts on this build. Thanks for the link though- I'll use it on another build.
    Nov 2007
    Does your caliper look like the first 2 pics? The hubs are White Industries 3 bolt disc hubs, but note that the rotors shown do NOT fit the rear hub bolt pattern - see pic 5
Size:  72.4 KBName:  Caliper 3.JPG
Size:  70.1 KBName:  F Hub.JPG
Size:  140.6 KBName:  R Hub.JPG
Size:  103.9 KBName:  R Hub Rotor.JPG
Size:  109.0 KBName:  F Hub Rotor.JPG
    My caliper looks slightly different and is front brake only.
    B A N N E D
    http://www.ashima.com.tw/Aineon-hub.html
    The NEON hub utilizes a patented 3 bolts design, but the configuration means it can also be used in conjunction with standard 6 bolts disks
    If your old 3 bolt rotors won't bolt onto a 6 bolt hub then they won't bolt onto a Neon hub.
    This is a 'Shocks and Suspension' forum, wouldn't 'Brake Time' be a more appropriate place to post this ?
    Quote Originally Posted by 1 cog frog View Post
    I'm in need of an adapter like this. PM sent.
  1. Rock Shox Reverb remote placement with XT brakes/shifters
    By andyb_aka_shredward in forum General Discussion
    Last Post: 08-31-2013, 02:57 PM
  2. Pick one!!! ROCK SHOX DART 3 or FOX TALAS RL or ROCK SHOX SEKTOR???
    By Tattootimmy in forum Shocks and Suspension
    Last Post: 06-18-2013, 01:47 PM
  3. Disc brakes in 1997
    By zygote2k in forum Vintage, Retro, Classic
    Last Post: 02-28-2013, 02:50 PM
  4. XT or XTR Brakes with Rock Shox Hydraulic Lockout
    By riding29 in forum Brake Time
    Last Post: 10-30-2012, 07:14 AM
  5. X-Post Brake Time:Rock Shox Disc Brake ?
    By 1 cog frog in forum Vintage, Retro, Classic
    Last Post: 08-30-2012, 06:33 AM
