Results 1 to 7 of 7
Thread: 12mm Thru-Axle?
    Apr 2013
    New question here. 12mm Thru-Axle?
    Basically, I'm looking for my first full-suspension bike, and I've been considering many different entry-level options.
    One of the options I'm seriously considering is the Diamondback Sortie 29er.
    I know DB isn't generally considered a bona-fide high-end brand since they all have big-box store models, but I like the look of the sortie because it is the only entry-level priced full suspension bike I've found with Fox fork and shock.
    The fork on the Sortie 1.0 has a 9mm QR and the Sortie 2.0 has 12mm thru-axle.
    // You can skip everything above unless you want background to the question
    QUESTION: Would a 12mm thru axle provide enough benefit over a QR to justify upgrading?
    INB4 "Just go with a better bike": I have a pretty strict budget. It's entry-level FS or sticking with my hardtail, so I'm looking at entry-level.
    waiting for a piece (.45)
    Reputation: SpecialWarr's Avatar
    I like them but I change wheels four times a week, so it just makes my life easier that way.... but in all honesty I've been riding 9mm QRs since the beginning of time and the only thing I noticed is that you don't need to hold the QR nut.
    Stiffness: 7-8 percent better on the 12mm
    Lightness: a dozen grams lighter than the 9mm
    that's my 2 cents!
    Apr 2013
    Thanks for the quick reply. I could definitely see the advantages of going to the thru axle if it were a 20mm, or even a 15mm, but I was just curious if it was really that much of a difference sine it is only a 12mm.
    Jun 2012
    Quote Originally Posted by SpecialWarr View Post
    that's my 2 cents!
    Is your "7-8 percent" based on empirical evidence, or are you just saying that?
    Ok I am confused. Front fork is listed as 9mm QR or 15mm thru axle. Rear is listed as a 12mm??? If you are debating QR vs. thru axle no doubt go for the thru axle.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Re: 12mm Thru-Axle?
    I've never heard of a 12 millimeter thru axle in the front.
    I think you're confusing the rear axle with the front axle.
    The 7-8 percent is empirical. I have a dyno that I put together some years ago that I used to use to test cranks that I've rebuilt to test suspension deflection.
  1. 12mm x 142+ thru-axle hub replacement
    By jmang in forum Specialized
    Last Post: 09-06-2012, 08:05 AM
  2. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  3. 6.6 12mm axle?
    By Elmo in forum Intense
    Last Post: 03-10-2012, 11:28 PM
  4. 12mm axle to QR adapter?
    By ihaveagibsonsg in forum Wheels and Tires
    Last Post: 02-28-2012, 11:11 AM
  5. 12mm Through axle?
    By big_slacker in forum Downhill - Freeride
    Last Post: 04-24-2011, 11:36 AM
