Results 1 to 3 of 3
    I Like Bicycles
    Reputation: Thimk's Avatar
    '12 Float 36 Knocking (Video inside)
    Would definitely want some insight on the issue I'm having. I've gone ahead and asked my LBS for a replacement air spring assembly, but I'd still like some input form anyone here. In short:
    • The knocking is coming from the left side of the fork (holding the left side while compressing definitely confirms this)
    • Rebound and compression adjustments have no effect on the knocking
    • Forks knocks at any PSI
    • There is no bushing play
    Here's a video:
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
    moaaar shimz
    Reputation: tacubaya's Avatar
    Looks like the negative spring is either hitting the stanchion or rubbing and clicking against the top out spring.
    I Like Bicycles
    Quote Originally Posted by tacubaya View Post
    That's what I'm thinking.
    The top out spring is the smaller of the two springs, yes?
    Is this a common issue? What's the common fix?
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
  1. Fox 36 Float - Loose Air Air Spring Rod? (Video inside)
    By Thimk in forum Shocks and Suspension
    Last Post: 04-15-2013, 06:51 AM
  2. Only if AZ had this.... Video inside!!!
    By HighTitan in forum Arizona
    Last Post: 03-06-2013, 04:15 PM
  3. Float 36 knocking/clunking noise
    By ChainChain in forum Shocks and Suspension
    Last Post: 09-01-2011, 07:00 AM
  4. Fox Float 150 RL Knocking
    By hungrytiger in forum Shocks and Suspension
    Last Post: 06-21-2011, 06:46 PM
  5. fox 36 float knocking when compressed
    By seadna in forum Shocks and Suspension
    Last Post: 01-13-2011, 06:13 PM
