Results 1 to 3 of 3
    Mar 2013
    1100lbs or 1200lbs spring for 6.5x1.5 Fox Vanilla?
    Weighing in at 260lbs in gear, I bough a used bike with a 900lbs spring on a Fox Vanilla All the spring rate calculators put me in the high 1000lbs to low 1100lbs.
    I know the rear shock is outdated and I should probably move to an air shock but is there any place that still carries these in stock? I've called Fox directly about finding a NOS vanilla shock and they said none are available so I doubt they would have springs alone.
    They'd be much more likely to have the spring than a NOS shock.
    Im not sure if you can find 1000+ lb springs from anyone, especially in that short size. How does the bike ride with the 900lb spring?
    Mar 2013
    I'll call back about the spring alone. But at 900lbs it's just so squishy, just sitting on it and I've blow through 1/2 the travel. I've only had experience with Fox Floats so coil spring rear shocks are still a mystery.
  1. Replies: 18
    Last Post: 02-08-2013, 04:10 PM
  2. Fox 36 Vanilla 160mm spring lenght/height ?
    By Vuco in forum Shocks and Suspension
    Last Post: 10-25-2012, 05:44 AM
  3. Wanted: old shock spring for Fox Vanilla RC
    By llatsni in forum Shocks and Suspension
    Last Post: 01-25-2012, 08:39 AM
  4. Replies: 12
    Last Post: 08-11-2011, 05:51 PM
  5. Grease for Vanilla Fork Spring
    By jsac in forum Shocks and Suspension
    Last Post: 05-27-2011, 01:31 PM
