Results 1 to 3 of 3
    '11 fox 32 talas fit rlc 140mm vs 150mm ??
    It appears that the 2011 fox 32 talas fit rlc is available in two forms. One with 140 mm of travel and one with 150 mm of travel. (both are adjustable).
    Is the longer travel fork 10mm longer axel to crown? Or are these forks the same length?
    Currently I have a 140 mm fox float on my Ibis Mojo and I would like to add travel. But, equally as important, I would like to slacken the angles by swapping out a longer fork.
    Is the 150mm 32 talas fit rlc going to change the overall geometry of my bike?
    Yes it should. Acording to the fox tech centre website the 140 is 510.9mm axel to crown and the 150 is 520.9mm. There are drawing under the product specification section of the tech centre which show this.
    More Torque
    Reputation: Diesel~'s Avatar
    You'll like the 150 on the Mojo. The TALAS is great if the climbs in your area are steep.
    -D
