Results 1 to 2 of 2
    1 1/8 inch to 1inch threaded steerer tube replacement?
    I have a Serotta T-Max and it has a 1inch threaded steerer tube. I just purchased a lighter fork (used) and they said it was a 1inch threaded tube but as I was installing it I noticed that it is a 1 1/8 not 1inch. Is it possible to switch steerer tubes because I can not return the fork?
    Former Bike Wrench
    If its a Marzocchi, you can contact them about swapping out to a 1" threadless...then just replace the headset and stem.
    Otherwise, the most likely scenario is no
