Results 1 to 7 of 7
    08 travis 150 tpc or domain 160 318is
    just want to hear from you guys which of the 2 is better. riding style. light freeride with only 6 foot drops. nothing extreme. wt. 160 lbs. bike: yeti asx. no marz n fox. to expensive. need a fork with least maintainance.
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Travis all the way... It's lighter, lower a-c, requires little to no maintenance... Just a much better fork all the way around. TPC+ rules... Easy to customize your shim stacks for your needs.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Those are both good forks. The damping system in both is excellent. The Domain is a little bit heavier, but the Travis is no light-weight either. Both forks will be very easy to live with as far as service issues. Both forks are stiff. Maybe it would come down to price?...or even the mundane issue of color.
    MattSavage
    Sep 2003
    Quote Originally Posted by TNC
    Well, in that case, it would have to be the Travis... I couldn't stand the stainless steel stanchion look, if it was me... Looks cheap to me...
    Aug 2005
    maxle and extra 10mm on the domain.
    thanks .
    MattSavage
    Sep 2003
    What did you decide on?
    Quote Originally Posted by atakiez
    thanks .
    ...i hope you say Travis...
