Results 1 to 2 of 2
    over researcher
    Reputation: royta's Avatar
    '06 RS Team Reba Dual Air vs new Reba?
    What are the internal differences between my '06 RockShox Reba Team Dual Air and the new Reba forks?
    I'm toying with the idea of suspension upgrades on my '06 Flux and really don't want to spend any money. I was wondering what kind of difference I would see with a Push job.
    Sent from my Droid using Tapatalk
    Nov 2007
    If you get a new Reba with the black box motion control damper it gets the dual flow rebound circuit. This is well worth having as it gives you the sorts of benefits that you used to previously look for in a Push factory tune.
    On the spring side, the negative chamber is improved with proper venting from the lower leg to the underside of the negative chamber shuttle. You also have a foam ring helping lubrication of the main piston o-ring.
    The titanium sprung motion control cartridge is supposed to be more precise and is certainly better made.
    The RLT ti model has all these features. In previous model years it was labeled a the Reba Team.
    Sent from my GT-I9100 using Tapatalk
  1. Replies: 0
    Last Post: 03-15-2011, 08:27 AM
  2. Reba Team 29 Dual-Air, adding spacer to get down to 100mm
    By morganfletcher in forum Shocks and Suspension
    Last Post: 04-02-2009, 05:47 PM
  3. 07 RS RVL 426 dual air vs REBA TEAM air u turn
    By stoneball jack in forum Shocks and Suspension
    Last Post: 01-06-2008, 04:53 PM
  4. Replies: 16
    Last Post: 03-17-2006, 03:38 PM
  5. 06 Reba Team Dual Air pressure discrepancy
    By royta in forum Shocks and Suspension
    Last Post: 03-17-2006, 06:15 AM
