Results 1 to 2 of 2
    Reputation: Hobietom20's Avatar
    05 Float R vs 03 Talas RCL
    I have a new, unused Float and a used 03 Talas. I am wondering about differences in ride quality. I like the fact that the Talas has adjustable travel and lockout (though I seldom use it). And, I know that the Talas will wear out faster because it has been used for a couple of years.
    My question is simply ride quality. Will I notice any difference between the two shocks? Has the ride quality improved sufficiently between 03 and 05 that it is noticeable or do the two shocks differ significantly (for example, I know that the Talas has near linear rate but I don't know about the Float).
    I mostly ride cross country as I am old, fat and slow. I do ride reasonably hard over smaller bumps and tend to wear things out because primarily of my weight (200 pounds) I think. If there are no real differences (or the Float is better), I will likely use the Float because it is newer and sell the Talas. If the Talas is better, I will likely keep it.
    Any advice would be appreciated.
    Now riding Fox Shox!
    Jan 2005
    I would stick with the talas. It has way more adjustability than the float r. Its probably time for new seals if you havent aready changed them.
  1. 05 Float vs 03 Talas
    By Hobietom20 in forum Shocks and Suspension
    Last Post: 03-27-2005, 01:36 PM
  2. 05 Talas or Float RLC 130?
    By verrocchio100 in forum Shocks and Suspension
    Last Post: 03-20-2005, 06:10 PM
  3. Replies: 3
    Last Post: 02-07-2005, 09:08 AM
  4. Pushed Fox Float RL 100 vs pushed Talas 05
    By motoadve in forum Shocks and Suspension
    Last Post: 01-21-2005, 02:50 PM
  5. Replies: 1
    Last Post: 10-19-2004, 05:32 AM
