    04 Manitou Minute 2/3 Set Up
    I have a Manitou Minute 3 fork and can not get it to sag!
    I have even run 70psi in the main and 50psi in the SPV and only get around 5mm sag (I weight 175lb)
    HELP!
    Has anyone here any experiance with this fork? - What do you weigh, and what set up do you find best?
    The fork feels great - I'm now running 90psi main, and 60psi SPV with 3 turns in on the SPV adjuster and damping set to 3/4 towards 'fast' BUT the lack of getting the fork to sag concerns me as I don't know if this is my optimum setting.
    Cheers!
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Don't worry. These forks don't sag the same way as a normal fork. It will take a push or bump to the fork to break free the spv valve. It won't sag as soon as you sit on the bike but will sag normally once the fork becomes active.
    Quote Originally Posted by Hecubus
    What do you recon to be the best way to set this fork up?
    Help
    Hi to all, i have a mintute 2 which the rebound knot was broke and i send to my LBS for repair. It came back after service where by they change the whole SPV damper together with the rebound knot in the fork. Now the fork became very sticky feel cause when press down it will not rebound back they say need to break in the fork again. Anyone have face this problem?
    Regards
    Chris
  1. Manitou wind down travel adj.....
    By AkDave in forum Shocks and Suspension
    Last Post: 02-14-2004, 12:57 PM
  2. Replies: 6
    Last Post: 02-02-2004, 09:04 PM
  3. Any tuning advice for the new manitou minute 3?
    By The Dude in forum Shocks and Suspension
    Last Post: 01-21-2004, 09:18 PM
  4. Manitou and xt disc
    By MerIIIcK in forum Brake Time
    Last Post: 01-19-2004, 06:14 PM
  5. help me choose TALAS R or Minute 1
    By ErrAzIb in forum Shocks and Suspension
    Last Post: 01-17-2004, 04:11 AM
