Results 1 to 1 of 1
    Is it play time yet?
    Reputation: erik99's Avatar
    '00 SID XC....left leg won't hold air?
    Hi,
    I just reinstalled my '00 SID after having it "serviced" at the shop. I attempted to adjust the air pressure in the left leg and all the air rushed out of the valve. I proceeded to refill the leg with air, but as soon as I unthread the pump the air again rushes out. I tried to see if the valve was obstructed or stuck, it looked OK.
    I called the shop and explained the issue and I got "Oh yeah, the mechanic was having trouble with that too. You need to bring it back". Nice.
    Anyway, I wanted to know if this is a common part to fail (the fork never had been apart or failed in 4 years of use) or a result of the work that was done. I know that might be hard to say. What does this part cost?
    Thanks for the look,
    Erik
  1. SID XC...Where to get it rebuilt?
    By erik99 in forum Shocks and Suspension
    Last Post: 06-17-2004, 06:26 AM
  2. SID XC air pressure question.
    By ButtGumbo in forum Shocks and Suspension
    Last Post: 06-16-2004, 09:33 AM
  3. noleen mega air fork leaking out left leg grease port
    By eman in forum Shocks and Suspension
    Last Post: 06-15-2004, 07:28 PM
  4. 00 Rock Shox SID XC
    By Salsa1018 in forum Shocks and Suspension
    Last Post: 06-04-2004, 10:45 AM
  5. 2001 SID XC Setup
    By Brihombre in forum Shocks and Suspension
    Last Post: 03-22-2004, 10:05 PM
