    MTK
    MTK is offline
    XTR's First 20mm Wheelset?
    Was it 2010 that it first came out? I cant remember? You could order the set
    with a Front 20mm. Also,can I still find a used set of these? Thanks.
    MTK
    Apr 2005
    I don't think there's been an XTR wheelset with 20mm, hub maybe, but I think XTR has only been QR, Lefty and 15mm. There's been an XT 20mm for a while.
    MTK
    MTK is offline
    I thought for sure
    XTR had one as well. If they did the XT,they must have done XTR? What year is the XT
    20mm you speak of? Thanks.
    MTK
    Mar 2012
    Shimano XTR has never produced a 20mm wheel set, only 12mm and 15mm. Really, the only way you can have a 20mm is to buy the XTR hubs and rims separately, but then Shimano doesn't even produce a straight pull 20mm hub, so you couldn't even build it.
