Results 1 to 5 of 5
    Mar 2011
    XTR Trail vs Race 2x10 -- Difference??
    A bit of misunderstanding in the difference between the Race and Trail versions when comparing 2x10 versions as I don't see differences. Is it solely in brakes?
    Also does anyone know if the new Shadow Plus rear derailleur will be part of an XTR kit/grouppo or will it have to be bought as seperate item?
    Reputation: DavidR1's Avatar
    The XTR Trail has different chaingring sizes. The XTR Race offers a 40/28 and 42/30 while the XTR Trail offeres a 38/26. The Q factor of the Trail version is also a bit wider, not sure of exact measurements.
    CyclingCentralVa.org
    Reputation: limba's Avatar
    The wheels and pedals are different too.
    whistler
    "race" cranksets also use a proprietary 88mm BCD and 1 common bolt to capture both rings (to save the weight of 4 chainring bolts!), whereas "trail" version uses "standard" 64/104 and 4 bolts per ring.
    Reputation: CrashTheDOG's Avatar
    I ended up going with the 2 x 10 XTR Trail crank because it gives me several more options of chain rings with the 64/104 and you can pull a couple of dust caps to allow you to run 3 x 10 or a bash guard.
  1. Race face Next sl and race face Turbine Sl with Shimano 2x10 drive train
    By kumarpr227 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2012, 09:38 PM
  2. Race Face 2x10 carbon
    By eddy02 in forum Weight Weenies
    Last Post: 03-22-2012, 02:57 PM
  3. 2x10 race face atlas fr?
    By KTMDirtFace in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-22-2011, 11:14 PM
  4. Replies: 4
    Last Post: 04-07-2011, 04:11 AM
  5. what's the difference between a 2X9 and 2X10 Setup?
    By ncativo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2010, 10:54 PM
