Results 1 to 6 of 6
    XTR Trail RD m985 cage replacement
    Smashed my inner and outer plates on my XTR shadow plus rear derailleur, LBS not having any luck ordering them.
    anyone know if the cage from a lower line shadow plus RD will work? XT, SLX, zee etc or where to order the xtr plates.
    Oct 2012
    Don't know but was looking for the same info to update an 820 Saint rear to a long cage..
    Reputation: dRjOn's Avatar
    iirc folk have swapped out saint and xtr...dont know about any others...
    MTB B'dos
    Reputation: LyNx's Avatar
    I just did an inner cage swap on an XTR from a lower model RD, maybe XT or LX, maybe even SRAM, it was in my smashed RD box already off) and it works fine. no luck in finding a replacement for the outer carbon cage part, so reinforced the broken lower pulley mount area with a piece from an old alu cage. Really would think that with the design and the cost, that you'd be able to buy and replace the cages.
    Oct 2012
    From the research I have been doing it seems the cage assembly from a XT with Dyna with shadow+ will work.. The non shadow+ one will not work as they don't have the right inner sleeve that the bolt goes into.. I learned this the hard way with buying an XT non + and it's not even close inside..
    Oct 2012
    Which model XTR? Shadow+ or non +?
  1. Broken XTR Cage - Replacement Parts?
    By yeqmaster in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-20-2014, 08:58 AM
  2. pad replacement for BR-M985
    By shanem in forum Brake Time
    Last Post: 02-11-2012, 11:59 AM
  3. XTR (M960) derailleur cage replacement
    By dopepedaler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 05:15 PM
  4. Aaron Gwin's short cage xtr m985 shadow mech
    By dRjOn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2011, 11:27 AM
  5. Replies: 16
    Last Post: 10-08-2011, 08:09 AM
