Results 1 to 30 of 30
    XTR Shadow "Plus" to be in XT line also?
    Like most, if not all, of the XTR concepts have made it to the XT lines, I'm hoping to see that happen with the rear Shadow Plus rear derailleur. XTR is sweet of course, but I refuse to pay $250 for a derailleur. I made that mistake when I paid nearly $250 for the trail pedals, only to see the same design in the XT line for $100+ less.
    We Ride In God's Country!
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Probably, but it will likely be until the next model year comes around. The new XTR features are usually exclusive to XTR for about a model year...
    nnn
    I've been hearing rumors that it will happen. I was talking to a rep that was hinting but not saying for sure. So hopefully
    I read somewhere that it may even hit slx before xt which is due for its 2nd gen 10 speed update this year
    anticipation.....
    Reputation: bustedup's Avatar
    I can't wait for one too!!
    Reputation: Rey Recinto's Avatar
    Mar 2005
    Reputation: bubba13's Avatar
    Does anyone know when the XT rear deraileur with the Plus will be available?
    Would like to have one for a new build and forgo the chain guide on a 2x set up.
    Portland Off Road Navagators
    Reputation: Milkman311's Avatar
    Aug 2010
    Quote Originally Posted by bubba13 View Post
    My LBS mechanic says ~July. I too anxiously await.
    Primative Screwhead
    Reputation: Feideaux's Avatar
    Apparently there is a version 2.0 for the clutch derrailleur as well:
    From SOC12: A Second Look at Shimano
    "The design has been refined since it was first introduced and the cam is now grooved so grease is not pushed outward and out of the clutch mechanism."
    Ego maniacs please object to my posts.
    Reputation: solitone's Avatar
    I'm also waiting for XT shadow plus, I'm just ordering the pieces for my new build. How long do we need to wait?
    At the Sea Otter the Shimano rep said all lines will come out with the Plus clutch in July/August. The cooler thing is a whole new line called ZEE is also being released. It's the new AM/DH line between Saint and XT. I'm anxiously awaiting this as it has a true short cage dérailleur like the old 8 spd line. It has larger pulleys and looks pretty compact and slick. It should shift really crisp with that short cage and of course has better clearance being a shadow and short cage.
    I've just heard that XT 2013, with shadow plus, will be available from september, here in Europe.
    I guess Europe gets products later. Bummer
    Reputation: eclipse24's Avatar
    July/August....that's awesome! I''ve also been waiting for the XT shadow plus.
    bike rider
    Reputation: Lelandjt's Avatar
    Zee is a renaming of Hone. It'll remain a heavier, less expensive version of Saint.
    Keep the Country country.
    Master of None
    Reputation: presslab's Avatar
    SLX and XT Shadow Plus derailleurs are in stock NOW at UniversalCycles.com. +rep me if I helped you out.
    Universal Cycles -- Shimano RD-M675 SLX Rear Derailleur - 10 Speed
    Universal Cycles -- Shimano RD-M786 XT Rear Derailleur - 10 Speed
    Quote Originally Posted by presslab View Post
    Too late, no rep for you
    Got my XT mid cage from them on Friday. Rode it Saturday and it works great! Very minimal chain noise from a 2x setup when the trail gets really rough. I even decided to drop the LRP chain guide.
    Upgrade to 10spd and clutched derailleur was worth it.
    bike rider
    Too bad I have to choose between gear indicators and the clutch since neither Sram or Shimano make 10spd shifters with indicators and clutch derailleurs won't work with 8&9 speed. I consider both features pretty useful but for now I'll take indicators over the clutch.
    You could use Shimano inline indicators:
    Universal Cycles -- Shimano Dura-Ace Inline Gear Indicators
    Quote Originally Posted by Lelandjt View Post
    Yes the do
    Shimano XT M770 10 Speed Trigger Shifter | Buy Online | ChainReactionCycles.com
    Just ordered some to go with my new xt shadow plus that arrived yesterday. I take the indicator off anyway can't see the need for them.
    Just waiting for my kind shock lev 150 to arrive early next week and happy days
    bike rider
    Quote Originally Posted by gazza007 View Post
    Yes the do
    Good to know they exist in case the itch for a clutch derailleur gets too strong. Shimano indicators aren't as easy to see as Sram's that wrapped around the bar, but better than nothing. I had a 25min Suped D today and glanced at my rear indicator a couple times to be sure what gear I was in after multi up/down shifts.
    bike rider
    Are you getting it from an LBS or online? If LBS do you know which distributor has them? I was under the impression that BTi, QBP, and KHS are the US distributors and none will have them till August. I'm after a 31.6 150mm, hopefully before the weekend.
    I'm in Australia so I think we get ours first. Pushies enterprise is the distributor seller.
    I pre ordered mine and it was sent on Monday so I should get it tomorrow.
    With the exchange rate it will be pretty pricey for you to buy from here. I paid $500 aus for the 150mm. I know if I buy from the USA it's the postage that's the killer
    Jun 2012
    Are they making an SLX plus?
    Yes they are. Ordered my SLX Shadow Plus mid-cage from Universal Cycles yesterday, it should be here by Tuesday. :-)
    Mar 2012
    Quote Originally Posted by ssalmons View Post
    Even thought this is for the Dura-Ace Line of products, will it work with the Dyna sys line?
    Living in Houston makes me more of a Ditch Bike Rider
    Man my bike needs a better motor
  1. "No Clue Crew" VIDEO - Fence Line Session
    By Grave9 in forum Arizona
    Last Post: 03-11-2011, 01:08 AM
  2. What's the "actuation ratio" for the latest M972 XTR Shadow rear derailleur?
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2009, 09:06 AM
  3. "Shadow" after model name
    By louisssss in forum Shimano
    Last Post: 09-10-2009, 09:47 PM
  4. Where is "High Line" and "Be Good" in the Shed
    By cableguy46 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 04-29-2009, 06:00 PM
  5. XTR "Shadow" vs. Dual Control
    By TrekFan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2008, 05:19 AM
