• 02-10-2013
    dypeterc
    XTR Shadow+ 1x10 chainguide needed?
    I'm currently running a 1x10 drivetrain:
    S-Works crank
    Renthal single chainring
    KNC chain
    PG-1050 cassette
    XTR Shadow+ RD
    Do you think I need to run a chainguide w/ this set?
  • 02-15-2013
    Kiwiplague
    I would. In fact I'm about to go a similar, and even with an E-13 guide ring, I wouldn't even contemplate not running a guide. I'm going the XCX BB mount XT cranks, XT shadow + and aforementioned chain ring.
    From what I've read elsewhere, without a guide the chain will still manage to fall off from time to time.
  • 08-15-2013
    barrymtb
    Re: XTR Shadow+ 1x10 chainguide needed?
    I just went to a 1x10 on my Rumblefish. Used the raceface narrow wide 36t chain ring. I have a xt shadow on the rear. First ride today I dropped the chain on the outside twice in 11 miles. So far only in high speed rooty banked turns. Never dropped it on the downhills over big hits. I assume having the bike really laid down with fast rough terrain caused it. Ordered a MRP direct mount 1x chain guide.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
  • 10-03-2013
    Under_Pressure
    I have a wolf 34t ring on a xt shadow plus rear and have yet drop a chain. Make sure your clutch is tight and turned to the on position!
    XT chain and rear cassette.
  • 10-03-2013
    epic
    XT Shadow or Shadow +? If you just have the regular shadow, there's your problem.
  • 10-03-2013
    JACKL
    Same here, except I'm running the Wolftooth 30t. No guides, no drops, and it's nice and quiet.
  • 10-19-2013
    plume
    race face NW on my dynasys drive train. flawless after 4 rides!
