    Reputation: lancelot's Avatar
    XTR M980 crank arm thickness
    Can someone please measure the crank arm thickness near the pedal on a set of M980 cranks for me? Thanks in advance.
    I bought a set and they measure approx 13.5mm's if anyone else needs this info.
    Reputation: Dover's Avatar
    Why do you need this?
    I'm having an issue with my crank arms hitting the chainstays while climbing technical tough terrain. I was running carbon cranks and they are pretty thick at the pedals so looking for thinner arms to avoid this. Both cranks are about as wide as they make them q-factor vise so I just needed a thinner arm to increase inside clearance.
