Results 1 to 3 of 3
    Reputation: mtbj's Avatar
    XTR M975 Dual Control Levers.
    Does anyone know how to take off the levers from XTR M975. I took the set pin out but cant get the pivot to slide out. Maybe its rivited???
    Reputation: Dover's Avatar
    there is a screw that holds the pivot in place. you have to adjust the reach adjuster all the way in and them pull the lever to the bar. you will see the grub screw on the inside of the lever at the pivot axel.
    I took the set screw off but could not slide the pivot axle out.
