XTR M975 disc brake hose?
I'm moving my XTR brakes to another frame and the rear brake hose needs to be longer for a different hose routing. I've been trying to find a replacement hose kit for the XTR disc brakes and none of the online stores list one and the Shimano Tech Docs don't even list the hose as an available part, just the barbs and olives.
Has anyone seen an XTR 975 hose kit or is it the same as any other Shimano disc brake? Usually there'd be something listed in the tech docs. How can they not sell a hose kit?
The doc you linked lists it as SM-BH59:
http://www.chainreactioncycles.com/M...x?ModelID=4422
Same part as M775 and M665 brakes. There are a couple other kits available with different end fittings (straight or banjo), but I'd be willing to bet that the hose itself is identical.
Doh! I scrolled right past the header and was looking in the parts list.
- You may not post replies
- You may not edit your posts
Forum Rules
