    Reputation: mtbnozpikr's Avatar
    XTR M970 Bottom Bracket Removal
    I am trying to remove the bottom bracket from my bike (already have the crankarms off) to cure some creaking happening down there but do not have either tools (bbt-9 or bbt-19) park tool makes to do the job. Considering these are probably not in stock at the local bike shops around here (SLC), I am trying to figure out a different way of removing it. Any suggestions/experiences with this?
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    ups and downs
    Buy the right tool or they will be mangled. There is no other proper way to remove and re-install the BB bearings. Skip the water pump pliers. There is quite likely a shop with the tools in stock, or there's these guys.
    Well, I wasn't going to try to use pliers or anything like that but I guess that my question is, will a strap wrench work? They are much easier to find and in that case I wouldn't have to wait for shipping.
    2012 Intense M9
    2008 Look 595
    Well, the answer is no, a strap wrench will not work. Heading to the shop tomorrow. Thanks for your input Rocky Uphill.
    2012 Intense M9
    2008 Look 595
