Results 1 to 5 of 5
    XTR Derailer Spring help
    Does anyone know if I can get a new tension spring for a XTR Rear derailer?? The derailer does not function well pulling back to the high gears..
    Thanks for your help...
    Dave
    No, but did you clean it up really good, like WD-40, or ATF and then a good air compressor blow.
    ...idios...
    Reputation: SteveUK's Avatar
    Have you adjusted the spring tension (small cam-screw inside the derailleur body)? Have you checked your cables for crud/gum? Both of these, I would say, are more likely than a worn-out spring. Here's a guide to overhauling your XTR.
    Diogenes
    I did flip the cam and the cables looked okay but probably worth looking closer.
    Thanks for hte great info!
    Dave
    PM Me for Wood Fenders
    Reputation: TrekJeff's Avatar
    Excellent guide Steve, I used it to over haul mine. well done.
    The wood is being bent! Let me know what you need!
