Results 1 to 3 of 3
    XTR 965 with 203 rotor
    Hello you all,
    Acquired from crc separate parts for my front brake system; XT 975 brake lever, XTR 965 caliber, XT 203mm rotor and Shimano Mount Adaptor Front IS to IS 203mm. When I finished bleeding the system realized that the caliber mounted 2cm higher than the rotor just touching it when I stroke the lever.
    Took it to my local bike shop and told me that XTRs are not compatible with 203mm rotor
    Any advice is welcomed
    Thanks for looking
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    are you sure you did not get a rear XTR caliper? (front and rear are different)
    Reputation: Dover's Avatar
    sounds like you have a rear caliper mounted on the front
