XTR 960 Int calliper on to Post mount 08 TALAS
Hi
Can I get an adapter to mount an XTR 960 Int mount calliper to an 08 Post mount TALAS??
Thats a 160 mm rotor..................sorry!
I Had The Same Problem
And so I started a similar thread, found here: Help With Post Mount Adapter
In the end, I just picked up an XT caliper and just switched them out. After a bleed, I can't tell the difference; the XT performs flawlessly. I've seen some XTR 960 calipers on sale at various online retailers lately, you may check & see if Jenson or Performance can't hook you up.
as blurredboy said, you can go to a PM caliper or increase your rotor size to 170 or 180mm and use a PM to IS adapter
- You may not post replies
- You may not edit your posts
Forum Rules
