Results 1 to 8 of 8
    XTR 2007 crankset FC-M970
    Hi, do you know if I can use my old XTR 2007 crankset FC-M970 with the new front derailleur FD-M981?
    the catalan connection
    Reputation: What&son's Avatar
    If Ive understand correctly what I have read about 9-10 parts compatibility you should match the derailleur type only with its crankset type.(9 sp front derailleurs only with 9 speed cranks and so on)
    There is a huge thread explaining most issues when mixing 9-10 parts.Here:
    Dyna Sys 10 speed compatability with 9 speed (Shimano systems)
    And welcome to the forums!
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    Oct 2007
    I am the guy who started the thread the previous poster linked. I had read in magazines that using a 10 speed front derailleur with a 9 speed crankset would work, but not optimally. However I am currently running a complete XTR 10 speed drivetrain but using the 9 speed M970 crankset. I have absolutely no problems with it despite what the magazines all claimed. So the answer is yes, you can use them together, as long as you are using a 10 speed chain.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Thank you for your answer, I would like to use my old XTR 2007 group on the new bike.
    3-9 crankset, 9 speed XTR cassette and 9 speed rear derailleur. On the new bike I must mount the new XTR direct mount front derailleur, so I was asking if in your opinion then new FD will work fine with the old crankset. The group should be all XTR 2007 9 speed with the exception of the front derailleur.
    Ops... googling I've found this: "The Shimano XTR Direct Mount Triple Front Derailleur FD-M981 is specifically designed for use with Shimano's XTR Trail Triple Crankset and 10-speed XTR chain, and the maximum chainring size is 42 teeth"
    My maximum chainring is 44... may be I can change the 44 with a 42... mmh...
    Oct 2007
    Quote Originally Posted by UncleSinger View Post
    As I said, I am currently using this derailleur with a 44, with no problems. You will have to use a 10 speed chain though.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Quote Originally Posted by ljsmith View Post
    Ok, thank you very much!
    Another yes on this, I have a Dyna-Sys XT M770 E-type with an M760 XT crank.
