    Are XT SL-T780 shifters Dyna-Sys ???? (note the "T")
    Cant seem to find info on this anywhere .
    Are XT TREKKING shift levers (Sl- T 780) also Dyna.Sys (Note the T , im not talking about the SL-M780 shift levers)
    Reason Im asking is I want to continue using a RapidRise rearmech , but with a 10sp cassette.
    I know I could just get the SL-R780 shiftlevers( "Ultegra level" flatbar 10sp. shifters) but they only come in F+R sets , whereas Ive found the Trekking SL-T780 shifter as a rear only at roseversand.de
    Reputation: GTscoob's Avatar
    If you want to keep your rapid rise rear derailleur, you'll need to use the road 10speed shifters. 780 is the XT dynasis model number and the other XT Trekking components are just brake levers with longer levers and crankset with bigger gears so I cant imagine that the shifter would be any different.
    There is also a XT "T"rekking NON shadow rear mech.
    http://techdocs.shimano.com/media/te...9830750215.pdf
    Looks like the T780 rear derailleur is 10 speeds so I'd imagine the T780 shifter would then also have to be 10 speeds. Kinda funny though that the T780 rear derailleur uses the traditional Shimano cable routing, not the Dynasis routing.
    Bike24 says it's Dynasis:
    Bike24 - Shimano Deore XT RD-T780-SGS Rear Derailleur long black
  1. Replies: 36
    Last Post: 11-24-2012, 07:18 PM
  2. Good "light lube" for my rebuilt shifters?
    By vikingshelmut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2012, 10:06 PM
  3. When does "Last Edited" note show up?
    By Mtn-Rider in forum test forum
    Last Post: 05-21-2012, 08:51 PM
  4. Replies: 3
    Last Post: 09-11-2011, 12:19 PM
  5. XT Dyna sys 2x10 using 771 "trekking" rings
    By velez3000 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2011, 04:54 PM
