Results 1 to 2 of 2
    Uncle
    Reputation: Entrenador's Avatar
    XT lever blade replacement
    Hi. I have a bent lever on my XT hydros, and from their technical documents, I get this part number:
    y-8s5 98070
    Anyone purchased one of these before, or know if they're available? Prices?
    thx
    Reputation: mtnkiwi's Avatar
    Used to get them in Japan pretty easily, about 10-15 bucks. Any shimano dealer should have them. Once you get the lever it is pretty easy to replace (don't forget to remove/loosen off the grommet screw before pushing the centre out), The grommet screw is located at the front of the lever (you can see it when you depress the lever). Hope you get it sorted and are up and riding again soon.
