    XT level 12-36 9 Speed
    Will Shimano ever make a 9 speed cassette with 12-36 cogs. I have seen the low end model, (cant remember the model name), but it is quite heavy. I have a 1x9 drivetrain, and it would be nice to get that slightly better gearing for climbing without adding (rotating) weight that the low end model would add.
    bump
    May 2005
    doubt it...10speed is current and when they get their act together there will be 11of them....but
    If you search the 1x thread, you'll find people who've modded 9spd XT/XTR cassettes by either placing the 36t cog off the 9spd SLX cassette or an Action Tec 36t cog behind the 9spd 11-32t cassettes, removing the 11t cog and placing a 12t lockring on.....pretty sure that's how it went?
    The purpose of the 12-36 9 speed cassette was for people who needed an easier gear than the usual 22x34 of a standard 27 speed setup, mostly 29 inch wheeled bikes that were 9 speed due to their pricepoint. Using a 12-36 to get easier gearing on a 1 x 9 drivetrain is pointless, for example, if you were using a 36t chainring and 11-34 cassette and were struggling a 12-36 cassette would give you that easier 1:1 ratio but so would dropping the chainring to a 34t and keping the 11-34 cassette plus 34x11 is actually harder at the other end than 36x12 plus you get more ground clearance, a shorter chain and lightweight cassette options. Just my opinion but thats what i'm doing till i can afford 10 or 11 speed.
