Page 1 of 2 12 LastLast
Results 1 to 100 of 149
    Jun 2012
    XT brakes with i-spec shifters
    Can anyone post a picture of XT brakes (or any model brake system) paired with an I-spec shifters? I am a bit of a noob to this but am planning to get the pair. Looking at pictures of the two products separately, I just can't picture how they go together.
    In addition, can anyone help tell me what I-spec part will pair up with the XT m785 part?
    Thanks forum, any help is appreciated.
    Reputation: PerthMTB's Avatar
    Its actually quite difficult to take a photo that shows how they go together, but have a look at these I just snapped...
    Basically the silver metal bar sticking out of the shifters inserts into a slot in the brake lever clamp, and a nut behind secures it. There is side to side adjustment of the shifters in relation to the brake lever only, achieved by losening the dome shaped nut dead centre of the second picture above. I find Ispec works very well, and reduces clutter (and weight) in the cockpit.
    To mate with the M785 levers you'll need to either buy the M780 I-Spec shifters, or the standard M780 shifters plus a set of SM-SL78 I-Spec Adapters to replace the standard indicator covers (although obviously thats a more expensive way to do it, but it gives you both mounting options).
    Edit: Here you go, this should make it much clearer, straight from the big 'S' themselves http://bike.shimano.com/media/techdo...9830747524.pdf
    Reputation: SpeedStarr's Avatar
    Here are a few more. I love this setup. XT brakes with i-spec shifters-imageuploadedbytapatalk1360334772.665861.jpgXT brakes with i-spec shifters-imageuploadedbytapatalk1360334784.847330.jpg
    Jun 2012
    thanks much guys! im hoping to get a set of xt brakes and shifters but was not too sure what part numbers match up. I guess I didn't look hard enough, but no where on jenson did it say what would pair up with what.
    thanks again!
    Any of Shimano's new generation of I-Spec shifters will mate with any of their new generation I-Spec compatible brake levers - so you can mix 'n match SLX, XT, and XTR to your heart's content. But if you want the pure XT combo, then the model numbers you want are brakes - BR/BL-M785, and shifters - SL-M780-I or SL-M780 + SM-SL78.
    Edit: I'm updating this because as of May 2013 the above is no longer true. Shimano have changed the I-spec interface on their "2014" model brakes and shifters so they aren't compatible with the 2012/13 I-spec levers and shifters. Confusingly, the new brakes and shifters still have the same model numbers ie. M785, M675, but have a 'B' after the model number to designate they are the new I-spec standard. So, for example the old XT lever was BL-M785, and the new one is BL-M785-B, and you'll need the SL-M780-B-I shifters to fit it. So, in future be careful you are fitting like with like.
    Jun 2012
    I appreciate it guys! hoping to order some soon.
    Jun 2012
    Does anyone know if the M660 can be paired with an I-Spec integration unit?
    Nope. SL-M660 can't be converted to I-Spec. You'll need the SL-M670-I
    Jun 2012
    Quote Originally Posted by PerthMTB View Post
    thanks! appreciate the info guys.
    Reputation: millertm's Avatar
    FYI, Blue Sky Cycles has I-Spec adapters on sale for $59.
    Mark
    2012 XXL Carve Expert
    Nov 2008
    I just purchased the I-Spec adapters for my xt set up. My question is - can I remove the gear indicators and install the adapters while the cables are in place?
    Quote Originally Posted by mmanuel09 View Post
    Haven't done it myself, but as the Shimano instructions say you need to remove the cable and cable adjusting bolt to fit the adapters, I'd guess that's a no....
    Nov 2008
    I called SHimano this morning. They said it can be swapped with the cables still in. All I have to do is remove the screws and take the indicator off and swap it with the ispec cover. I'll let you know how it goes.
    Cool! Maybe they should update their instructions to reflect that fact then...
    i swear it wont be long before i'll ban myself () from MTBR. i just took a hard look at my cockpit and looks like getting the i-spec adapters is very enticing.. would just need to convince myself to get a pair.. grrrrr.....
    2014 TREK FARLEY
    2013 TREK RUMBLEFISH PRO
    2012 TREK SUPERFLY AL ELITE
    looking forward for you reporting back how your install went.. am thinking of getting the i-spec adapters as well but the part about taking out the cables have me worried.
    thanks in advance.
    2014 TREK FARLEY
    unexpectedly got my I-SPECS last saturday and installed it sunday. install was ok. i did not have to take out the cables. only challenging thing i encountered was having to keep one of the left (FD) shifters out of the way for me to put in one of the screws.
    2014 TREK FARLEY
    Nov 2008
    Sweet. It can be installed without removing the cables. I'm on it. I got sidetrack with putting another bike together. Thanks for the update bapski...
    Sep 2004
    It's hard to adjust the side to side placement of the shifter on the i-spec once it's installed. If you can get a wrench in there maybe you're fine, but the 4mm or 5mm, can't remember the size, it blocked by the brake lever body. Maybe I did something wrong but it's certainly a small annoyance. Yes it's something you don't change more than once or twice, but it sucked having to take it all apart to slide the shifter over.
    Don't get me wrong though, love love love the brakes and shifters.
    Quote Originally Posted by notenoughtime View Post
    i think you'd need a 7mm spanner...but yeah its a pain having to re-adjust it after knowing i had it too loose and had to take everything out again.
    2014 TREK FARLEY
    Sep 2004
    Quote Originally Posted by bapski View Post
    Oh, I should try that. My shop is in shambles so I didn't even think about it. It had an allen head on it so that's usually my preferred tool.
    Nov 2008
    Hey guys. I finally got around to setting my ispec set up but failed horribly. I was able to swith out the cover but when I tried to hook that piece into the brake lever clamp it would not fit right. I looked and looked but I just don't see how they piece together. Did I get the wrong ispec (SL 780)? I've got 10 speed xt shifters and 785 brakes. Please help a brotha out?
    it will not really hook securely until you tighten the M5 bolt... see step 3 on assembly: http://bike.shimano.com/media/techdo...9830747524.pdf
    2014 TREK FARLEY
    Nov 2008
    Thanks for the reply bapski but the little hook won't even fit all the way through the hole. That's where I'm confused.
    Nov 2008
    I just got off the phone with shimano. I guess I have a different type of 785 brake lever (I think he said newer version but I'm not sure). This brake clamp needs the newer hardware and newer shifter to work with Ispec. So I'm hosed. Check out the website:
    SHIMANO Dealer's Manual / User's Manual
    SL-M780-B-I
    Click on DM-SL0001-02
    scroll to page 9.
    Does anyone want to buy a pair of Ispec mounts. Feel free to PM me. My loss is your gain.
    Reputation: parkp81's Avatar
    SL-M780-B-I
    scroll to page 9.
    Didn't know there are different M785 brake levers? I thought they are the same. I just looked at mine that I bought back in 2011 and it appears to have the hole at the bottom where you would mount the i-spec. I wonder what yours looks like? Can you take a picture? I'm thinking of doing this i-spec conversion in the future with my M780 XT shifters coupled with M785 XT brakeset, don't want to run into a problem like you did.
    Nov 2008
    Yeah I didn't know that either. The new 785 has a different clamp. With the new version that I have, only the new shifters will clamp on. They don't have the adapter available yet. In the link I have shows the diagram on page 7. I'll try and take a photo as soon as I can.
    I see what your referring to now. Damn I hope the front brake I get back from Shimano warranty comes with the same old type not the new type, or else I'm going to have 2 different types of i-spec mounts. I will find out tomm
    Yeah, I just received a set of the 'new' 2014 M785 brakes I ordered for a mate, and they don't fit the 'old' 2013 I-spec shifters. What was wrong with the existing I-spec standard that Shimano had to go and change it? And couldn't they have given the new incompatible levers and shifters a new model number - like M786, so at least it is clear what fits with what. I can see a whole lot of confusion setting in over the coming months as these hit the shops...
    SL-M780-B-I
    scroll to page 9.
    are these the I-spec shifters that you got?
    Amazon.com: Shimano XT SL78 I-Spec Bracket Set: Sports & Outdoors
    2014 TREK FARLEY
    @trailgrinder
    Reputation: Live2rideUtah's Avatar
    Now I am wondering what I spec I need to get for the xt's on my 2012 superfly. Can someone take a pic of the hole that I need to have in order for the above linked covers to work with my set or direct me in the right direction to what the hell I'm looking for. Thanks
    This should help clarify some confusion. Here is a picture from the manual of the new vs previous.
    @trailgrinder
    Alright I'm going into the garage to check it out. Thanks.
    Quote Originally Posted by Live2rideUtah View Post
    As yours is a 2012 model bike it'll be fitted with the 'original' I-spec levers. The new I-spec standard has only just been introduced and only a few shops have received new stock, and 2014 bikes will come fitted with it.
    After looking at a couple of online retailers that have the new models, it seems the new I-Spec levers, shifters, and adapters are designated with a "B" after the model number. So, for example the original levers were BL-M785, but the ones with the new I-spec standard are BL-M785-B. Similarly, the original I-spec shifters were SL-M780-I whereas the new ones are SL-M780-B-I, and the new covers/adapters are SM-SL78-B.
    So, as long as you avoid anything with a "B" added to the model number you should be alright. However, this may be easier said than done, as bike shops/online retailers are already confused by the sheer number of parts they have to stock with tiny differences, so what are the chances they'll know if what they're offering you is original or 'B' ?!?
    @trailgrinder
    Okay sweet, went into the garage and took a look around, now I just need to make sure and stay away from the newer ones. I guess I will look around and see what I come up with. Thanks for your help.
    @trailgrinder
    36.00 from a reputable retailer. I'm stoked. Guess I will wait and see if mmanuel up on top has the mounts that work for me and I will help him out and buy them from him.
    Came across this website doing some research.
    BTI | Shifter Service Parts from Shimano (page 1)
    "B-type i-spec model is compatible with 2014+ B-type Shimano brakes and can be used with 2011+ i-spec compatible Shimano brake levers with the special nut (included)"
    I guess this will save the confusion when they do release the new adapters, so it will work with 2011-current.
    That's good info, and together with the diagram from the Shimano manual you posted above, it looks like the new 'B' type shifters are backwards compatible to the old levers (with a special nut), but old non-B shifters won't fit the new 'B' type levers ? Confused yet !?!
    Seriously, this crap has got me all twisted. I think I am done, lol.
    Nov 2008
    Sorry for the delayed reply everyone. You guys are on it. It's the B type that you have to be aware of. I took some pics from my iphone and here is is what it looks like. I asked the rep if I can just snip the hook part and he said its possible but problem is that the bolt package is totally different. Shimano has not yet released an adaptor set and the bolt package is not yet available. I have another set of xt brakes on my niner. I need to see if my ispec adapter will fit those levers. If so, I'll have another night in the garage with some tasty beverages....
    XT brakes with i-spec shifters-xt-clamp-1.jpg[ATTACH=CONFIG]803551[/ATTACH
    Attached Thumbnails Attached Thumbnails XT brakes with i-spec shifters-xt-clamp-2.jpg
    Nov 2008
    OK. I just checked the xt brakes on my niner. This set is in fact the older set and not the new B set.
    So I spoke with Shimano and they said the new "i-spec mounts/adapters", when released will be backwards compatible with models from 2011+ to current. Had to make sure since now I have a new i-spec lever on the left and the old i-spec lever on the right, .
    Quote Originally Posted by parkp81 View Post
    Yeah, that's OK if you haven't already got the 'old' I-spec shifters, but for those of us that do, they aren't forward compatible to the new levers. So, if I break a lever in the future and replace it with a 'new' one, I have to buy a new set of shifters or adapters at the same time
    Re: XT brakes with i-spec shifters
    True. Didnt think of that for those that already have the current ispec mounts. I should have asked them why they changed it if it was working.
    Sent from my SCH-I535 using Tapatalk 2
    Yeah, that'd be interesting to know. There must be a reason for them to create all this confusion, just hope its not something serious that's gonna come back and bite all us version 1 I-spec users in the bum!
    @trailgrinder
    Ordered my adapters I am pumped to get them installed and lean up the cockpit a bit
    Nov 2012
    for anyone looking at brand new xt shifters, I just found the ispec shifters at arts cyclery for $120 shipped. Seems to be the best price I could find on them. I had slx shifters previously which worked fine but now since I recently upgraded to a set of 785 brakes that I got for nothing I'd like to match em up and clean up the handlebar a bit. They are the older ispec and listed as closeout so presumably they are making room for the new ones.
    Nov 2012
    Scratch that. When I put them in my cart it specifically said they were in stock. After I placed the order I got am email saying they were back ordered and they would inform me of availability within 1 business day. If they can't source the old ones for me hopefully they will honor this price for the newer version.
    Sent from my DROID RAZR using Tapatalk 2
    @trailgrinder
    Just a follow up, I have installed my I spec adapters which took me about 20 minutes and they came with excellent instructions as well. I can't believe I didn't do this sooner!
    unpossibles
    Reputation: Josh_SL2's Avatar
    Mar 2012
    Do you know if anyone has the b-spec adapters in stock? I can't find them anywhere. Unfortunately I just got the wrong kit in the mail and went through the whole failed install like some of you, because I have b-spec levers. I already have ispec levers on my hardtail and I love how clean and uncluttered the bar is.
    Oct 2010
    Quote Originally Posted by Josh_SL2 View Post
    I'm also looking for the b-type i-spec adapters, part number SM-SL78-B according to Shimano's website. Searching for that part # turns up only a few websites, all out of stock. May swing by my LBS this afternoon and see if they can order it for me.
    MTB doc
    Jul 2013
    You have to be sure to remove the piece of plastic between the covers of the shifter . If you don't do that the adapters are not going to going to fit .
    MTB doc
    Jul 2013
    Remove the pin plate . That way everything is going to fit the way suppose to .
    I just installed type-B shifters (SL-M780B-I) onto type-B M785 brakes (BR-M785-B), and the shifters are loose when the mounting screw is tightened down. It is barely loose, but it is loose. Has anyone noticed this too, I have disassembled it several times, and I think it must have been by design.
    Can anyone confirm that this is ok?
    Sep 2004
    I know they have a revised model out, but I don't know much about it. My version of i-specs are snug, no wiggle at all. I believe they are the older ones. Sorry can't help more.
    This image helps illustrate the differences between the "conventional" and the "NEW" type-b style
    I found that I can put a washer between the Shifter and the Brake lever and it tightens up. However, it's not a clean fit and will probably damage the mount after many miles of use.
    I wish I had a way to ask Shimano about the loose fit and get an official answer if that is what is intended.
    Oct 2010
    Quote Originally Posted by aaronrryan View Post
    Contact them, I'm sure someone will get back to you.
    MTB doc
    Jul 2013
    You need to call shimano because that's the 2014 lever and shifter . I have the 2013 models and the configuration is perfect . I don't know for what reason they changed for 2014 models .
    I called in and I was very impressed that the first guy I talked to, knew exactly what I was talking about. I haven't had a support call like that in quite a while. Kudos to Shimano.
    Now for the content of the call. The guy told me that it is NOT supposed to be loose. Since I didnt buy the parts from a bike shop, I couldn't just get it replaced in the shop which is what they would normally recommend. But instead I would need to send it in to him if i wanted it fixed.
    I told him that I could put a stainless steel washer between the shifter and brake and it tighten's it up, and he said if it wasn't an issue for me, it would be fine and would NOT void my warranty.
    Here is an image of where I put the washer:
    Maybe one day I'll send it in, but for now, I'm just gunna put a washer in there.
    Quote Originally Posted by mayonays View Post
    Were you guys able to find a place to purchase from? I just got a new bl-m785 lever and need to mount my old shifters on it.
    After using my bike for a while, the i-spec type b mount seems to have changed a little, to the point that I'm able to remove the washer, and it will tighten down properlynow. I'm guessing I just need to work the shifter back and forth a little to get it fully seated properly.
    unpossibles
    Mar 2012
    I found them on amazon this week but I haven't ordered yet. Shimano Xt I-Spec Brackets Sm-Sl78-B
    Amazon.com: Shimano Xt I-Spec Brackets Sm-Sl78-B: Sports & Outdoors
    Perfect! Just placed an order. Thank you!
    oh, that is really annoying, thanks guys I will now order the correct adapter and send back the wrong one. thanks for the help.
    Mar 2013
    Yep, im confused. I had to read this thread 3 times. I think its mostly because there is so much talk of two ispec generations of levers, 2 generations of shifters, and now 2 generations of shifter adapters.
    Just wanted to highlight the above since thats the exact info I was looking for and didnt find it so obvious during my first read of the thread.
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    TR
    TR is online now
    Angry bunny
    Reputation: TR's Avatar
    Reviving this thread.
    Ordered M785 brakes and an M780 shifter to mate up using i-Spec.
    Sadly when they have arrived the brakes are M785B which means they are not compatible.
    What do I need to make them work?
  67. #67
    Quote Originally Posted by TR View Post
    You need to either return the shifters for B spec units or return the brakes for a A spec units. Personally, I would go the A spec brake route as these will work with both A and B spec shifters. This might help down the line.
  68. #68
    Mar 2013
    or buy a handlebar clamp style for the shifter, forgoing the ispec
  69. #69
    TR
    TR is online now
    Angry bunny
    Returniong them is not an option as they were purchased online.
    There is no adapter available?
  70. #70
    Mar 2013
    I thought this whole thread was about the adapters..
  71. #71
    TR
    TR is online now
    Angry bunny
    YEs, but I mean an adapter to make the old style shifter work with the new style brake lever assembly.
  72. #72
    Mar 2013
    Posts on the 2nd page indicated (at least the way I read it) that if you have new B levers and A shifters youd need the B adapters for the shifters to make them fit....
  73. #73
    TR
    TR is online now
    Angry bunny
    Ummm, yes I have read that too, but I am trying to understand whether there is an ability to just buy the new clamp assembly and then make my old shifter work with the new brake.
  74. #74
    Mar 2013
    the only options right now are to purchase the entire shimano adapter or purchase an aftermarket clamp to mount it back onto the handlebar KCNC I-Spec Shifter Clamps : Fairwheel Bikes, Cycling Boutique
  75. #75
    TR
    TR is online now
    Angry bunny
    Stupid Shimano.
  76. #76
    You can buy an adapter for shifter and it will work with NEW brake lever. That's what I did.
  77. #77
    TR
    TR is online now
    Angry bunny
    Quote Originally Posted by The RideR View Post
    Excellent, will look at that or else just by the bar mount bracket.
  78. #78
    Apr 2005
    Love this setup!
    Quote Originally Posted by SpeedStarr View Post
    Here are a few more. I love this setup. Click image for larger version.
ID:	769704Click image for larger version.
    This is exactly what I have in mind for my bike, love the XT shifters-XTR brakes setup! How could you match these? I haven't seen any other around...
    Ok. I have a 2013 Giant Anthem X1 29'er with SLX shifters and I bought 2013 XT brakes to replace the Avid brakes. I am going to try to combine the shifters with the brake levers, hopefully de-cluttering my bars, but before I try it, has anybody here already done this or does anybody know for sure that it will work with these specific models?
  80. #80
    Oct 2013
    Hi Guys.
    Has anyone modified the original I spec shifters to work with the B type brakes. Both my bikes have B type but a mate has just bought a new Cannondale with B type XT brakes and wants to use his existing Ispec (early type) XTR shifters. Comparing his to my B type, the only difference seems to be the extra hook which I think we could just cut off. The only issue I can see after that is sourcing the nut and pin used for the B type which he obviously does not have.
    Has anyone done this or looked into it? Does anyone know if the nut/pin are available seperately?
    Thanks.
    Steve.
  81. #81
    Reputation: sand wedge's Avatar
    Sep 2012
    I ordered XT M785 brakes, XT M780 shifters, and XT M780 iSpec shifter covers. Unfortunately, I was sent XT M785-B brakes. Can anyone tell me besides returning the brakes for the conventional M785 versions, would changing the iSpec covers to the B versions solve my issue? In other words, would the XT M780-B iSpec shifter covers mate with the conventional XT M780 shifters?
  82. #82
    Sep 2012
    I called Shimano and spoke to tech support asking if the iSpec B covers would fit the conventional shifters. His response was to send all my componets back and have the dealer send back all conventional versions or all B versions. I said that was not my question and asked him again if the iSpec B covers would fit the conventional shifters, his response was "I don't know"...
    As TR posted "Stupid Shimano"!
  83. #83
    Quote Originally Posted by sand wedge View Post
    Yes, they will. That's what I had to do.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  84. #84
    Sep 2012
    Thanks The RideR, at least it's the cheapest of the 3 components. I'll have to wait and see what CRC will do.
  85. #85
    TR
    TR is online now
    Angry bunny
    Part of this issue is directly attributable to the fact that CRC has incorrectly listed the brake levers and not nominated them as "B".
    Exactly the same reason I got the wrong ones.
  86. #86
    Oct 2007
    Wondering if anyone has had luck finding just the bolts to go from B type shifter to the older style brake levers.
    Sep 2012
    Update, CRC sent me a new iSpec B adapters under warranty. Very impressed with their customer service and i see now they updated the listing for the brakes to include A or B.
  88. #88
    Hi guys,
    i just mounted my new XT brake levers and ispecs shifters. It's all 2014 so it fits theoretically. However, although assembled as said in the manual (DM-SL0001), the shifter is a little bit loose. It is tilting around the bigger black bolt which connects shifter and brake lever. I think the fitting between the little horizontal screen and the black bolt is not tight enough. Anyone else having this issue?
    rubber side down
    Reputation: TAOS1's Avatar
    Feb 2013
    Looks like I have the same situation; I purchased the XT BL-M785-B brakes and a XTR SL-M980-A shifter....
    So from the research I've done, is it true that these won't pair properly using the i-spec?
    That would be completely f'd
    EDIT....yes, completely f'd...great job SHIMANO! Should have went with SRAM....Good info in this thread...thanks!
    From Amazon for the adapter
    Item Description
    • To convert standard XTR-980 and XT-780 shifter units to i-spec integration with corresponding brake levers
    • SH-53624 and SH-53625: are compatible with 2011-13 Shimano brake levers (M988/985/820/785/675/666/640/596) and are not compatible with 2014+ B-type brake levers
    • B-type i-spec model is compatible with 2014+ B-type Shimano brakes and can be used with 2011+ i-spec compatible Shimano brake levers with the special nut (included)
    • Sold as a set for left and right shift levers
    Quote Originally Posted by misterbill View Post
    You must be really bored if you have read this entire post.
  90. #90
    Jul 2013
    My XT shifters mate with my XTR brakes, but the manuals must be for the previous iteration of i-spec, as the hardware and the way the two parts fit together looks nothing like what I have!
  91. #91
    May 2013
    I-Spec I means integrated right? So it is basically single piece shifter/brake lever together.
  92. #92
    rubber side down
    Feb 2013
    I am frustrated with this issue. I ended up sending back the XTR shifter. Now I'm on the fence to either stick with Shimano or go with SRAM.
    If I do go with Shimano and have the XT BL-M785-B brakes what 10sp right shifter would I need....
    Is the SLX as smooth and crisp as the XT?
  93. #93
    I've got all SLX on one bike and all XT on the other. Most things I can't notice any difference, but the XT shifters are noticeable better - they just seem more positive, smoother, and require less effort. I remember reading that the XT uses more ball bearings versus nylon bushings in the SLX, so that could be the reason.
  94. #94
    Nov 2012
    The slx brakes are EXACTLY the same as the xt brakes minus the free stroke knob or whatever its called. Largely considered a useless adjustment. As mentioned the xt shifters are better than slx . you need the xt b spec shifter
    Sent from my XT1080 using Tapatalk
  95. #95
    Sep 2012
    Quote Originally Posted by TAOS1 View Post
    I have all 3 shifters, each level feels considerably better. The SLX are a good basic shifter but have a long throw and as mentioned earlier, are not as precise as each level up. My original plan was to upgrade to the XT but found they come only with the shifter displays and to remove them, you would need to purchase the covers. Another dumb ass move from Shimano. I found an amazing deal on XTRs and have no regrets. One last stupid move from Shimano is that they removed the side to side adjustment in the current regular (non iSpec) XTR shifters.
    I still question what Shimano is thinking when features are removed or changed from the previous models...
  96. #96
    anyone get the older problem solver mismatch adaptors (mounts sram shifter on shimano brakes) to work with the newer -b style brake lever? I'm guessing all I need is the bolt and hardware to mount the old adaptor to the newer brake lever?
  97. #97
    Hi, I have the BR/BL-M785 XT brake set (no - B that I am aware of) and want to install an i-spec Saint shifter. I pulled the right lever off and it does not appear to have the cut out for the hook that is shown on the shifters in the Shimano tech docs. Has anyone else run into this? Brakes were purchased about a year ago. I could grind the hook off I would think as the nut would still hold it tightly together.
    Thanks,
    John
  98. #98
    May 2010
    I guess I'm stupid but I really can't figure out how to attach i-spec XT gear lever to XT brake lever?
    Both, XT brake levers and gear levers(BRM785 and SLM780) say in their boxes that they are b-spec but they doesn't seem to be compatible. Or at least I don't understand how. And it doesn't help that there no instructions included.
  99. #99
    Jul 2013
    Quote Originally Posted by RaikkuFIN View Post
    When I get serious about putting my bike together, I'll look for the proper instructions, but I think I've figured out how to mate the XT and XTR parts, but both came with instructions for what I believe to be the previous version with the "hook" on them. The new ones are quite different in appearance an hardware (at least compared to the instructions!).
  100. #100
    Mar 2013
    Shimano has instructions for all their products on their website.....
Members who have read this thread: 33
