FAT BIKES
WINTER APPAREL
TRAINERS
Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 126 to 146 of 146
  1. #126
    Oct 2013
    Upgrade from Deore M591 to XT M780 i-spec B
    hi all, I have just upgraded my shifters to XTs I-spec B and I captured it in a video. Let me know if you have any questions. BTW, love the XTs.
    https://www.youtube.com/watch?v=F7eM8Upd4kI
  2. #127
    Same situation- a spec lever leaked, b spec lever arrived in the mail. So, I ordered the b spec cover, this is what is required to run a spec shifters on b spec levers, correct?
  3. #128
    Does anyone want to sell me their bar clamp mount for the XT left shifter?
    There's no forward/backwards adjustment with the ispecs unless I move my brake levers.
  4. #129
    aka mtbdennis
    Reputation: dirtbyte's Avatar
    Does anybody know if it is possible to direct mount (i-spec-b) a new 11 speed shifter pod to an XT I-Spec-B brake? Currently I have an XT i-spec-b shifter mounted to an i-spec-b brake lever, and just want to upgrade the shifter/der/cassette/chain to 11speed without getting new brakes or adding a separate bar mount for the shifter. I really wish shimano would not have introduced the "B" stuff, just makes it really confusing.
    "You either want to or you don't."
  5. #130
    Reputation: PerthMTB's Avatar
    I understand Shimano has introduced a third I-Spec standard with the new 11 speed XTR M9000 series, called I-Spec II and it isn't compatible with the previous I-Spec standards. So the answer would be no, but I'm only going by what I've read in the announcement material for M9000 and haven't actually had my hands on any of the kit, so someone who has may be able to confirm or suggest a workaround.
  6. #131
    aka mtbdennis
    Well f◊#$&! So basically I got royally screwed with the "b" standard crap. Only 1 model year for it. So if I need replacements they will be hard to find and probably more bank too.
  7. #132
    Update - Here's someone from another thread who has tried what you want to do, and confirms it won't work out of the box, but seems to have found a workaround by machining the aluminium...
    New 2015 Shimano XTR 1x11
    The shifting of the new XTR M9000 is fantastic - typically smooth Shimano shifting.
    The new XTR SL-M9000 I-Spec II shifter is not compatible with any of the other Shimano XT M785 and below I-Spec brake levers. It appears to be only compatible with the XTR BL-M9000 brake lever at this stage.
    But were there is a will there is a way - machining aluminium.
    XT brakes with i-spec shifters-923050d1410593879-new-2015-shimano-xtr-1x11-xtr-shift2.jpg
  8. #133
    aka mtbdennis
    Quote Originally Posted by PerthMTB View Post
    Thanks! Hopefully by the time I get around to doing this someone like problem solvers has a product I can purchase to solve this problem! Thanks for the info, seems all hope may not be lost! For such a simple interface I have no idea why they need to keep changing the "standard".
  9. #134
    I too have no idea why Shimano went from I-Spec A to B, except the B attachment method is more substantial so maybe they had issues with A not being strong enough?
    I-Spec II on the new XTR 9000 stuff allows rotational as well as lateral adjustment, which has been a big criticism of I-Spec A & B (although it never bothered me), so that must be at least part of the justification for introducing yet another standard.
  10. #135
    That means the m9000 shifter with I spec II is not compatible with my m820 brake lever?? I remember reading somewhere that said it could be converted ...
  11. #136
    Nov 2014
    Yup, The M9000 Shifter with the I-Spec II is not compatible with any of the old I-Spec designs. I just got my I-Spec II shifter today and it is mounted on to the shifter by sitting in the handlebar clamp well of the M9000 brakeset. I tried mounting it to a M987 brake lever and it wont fit as the new brakes have a different clamp design.
    So I've got to go get the bar clamp shifter now. I've tried every iteration and workaround, but there is no secure way to fit the shifter to the I-Spec B fitting.
  12. #137
    Reputation: juanbeegas's Avatar
    Oct 2007
    Does anyone know if the XT I-Spec covers are exactly the same as the XTR I-Spec covers? Would an XT cover fit an XTR shifter and vice versa?
  13. #138
    I was able to mount ispec b shifters on ispec a xt brakes. I used the clamp bolt that came with the brakes (they are the perfect length), nuts from toe clip bolts, and very narrow washers.
  14. #139
    Quote Originally Posted by bigleg82 View Post
    That's not the problem, its the other way round that's the issue - ie. I-Spec A shifters on I-Spec B brakes. And the B shifters should have come with the proper hardware to mount to A brakes.
  15. #140
    Quote Originally Posted by juanbeegas View Post
    I'm looking for this info as well - anybody try it and confirm if it works?
  16. #141
    I need a help: is it possible to convert SL-M670 to SL-M670ispec? If yes what parts do I need for?
    2013 Specialized Stumpjumper FSR Comp 29er
  17. #142
    Sep 2014
    So is it possible to use ispec shifters with the regular XT BR-M785 brakes?
    Sent from my iPhone
  18. #143
    B A N N E D
    Quote Originally Posted by rc mike View Post
    What I-Spec?
    I-Spec A, I-Spec B or I-Spec II.
  19. #144
    Sep 2014
    I assume B?
    Sent from my iPhone
  20. #145
    B A N N E D
    I assume B?
    For 11 speed you will need the SL-M8000-B-I which is currently not available, several shops list them but nobody has them in stock at the moment.
    http://si.shimano.com/php/download.p...0-B-I-3948.pdf
    For 10 speed you will need the SL-M780-B-I which shouldn't be too hard to find.
    http://si.shimano.com/php/download.p...0-B-I-3533.pdf
    I-Spec A shifters & I-Spec II shifters aren't compatible with your brake levers.
  21. #146
    OOOOOOOh Gee Are Eee
    Reputation: Ogre's Avatar
    Feb 2005
    What a load of s**t. Shopping to build a bike and this is still a disaster.
    If I have iSpec B levers can I use them with i Spec II shifters? I assume no, which means Shimano now has 3 incompatible specifications in 3 years time with resellers selling parts from all 3 years simultaneously.
    SRAM's lever consolidation stuff is a bit awkward but a cakewalk comparatively.
Follow MTBR on Facebook
