Results 1 to 64 of 64
    Reputation: HTR4EVR's Avatar
    No good The Worst Shimano Hubs Ever - Shimano HB M475 VIAM
    I got this in a pair of WTB Speed Disc. Less than a year and they are fry. Stay away of this shimano crab. A hub from a walmart bike is much better...:
    ...idios...
    Reputation: SteveUK's Avatar
    How much of this did you do?
    Diogenes
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    Those hubs are fine.
    Look at the time!
    Reputation: lelebebbel's Avatar
    Jan 2005
    the problem (as with all low end shimano hubs) is that they usually come preadjusted with WAY too much bearing preload. An unsuspecting rider will not notice this until it is too late.
    Adjusted properly, they are ok. Although the "seals" do suck.
    wanted: Cannondale Lefty w/ V-brake studs
    It's a bad hub problem. I know bwcause the hubs I use in every ride are this:
    SHIMANO XT DISC M756 HUBS
    Never has a problem in years. But some ocasional riding with the M475 and they die. Not the best for Shimano. At least they are the same size of the SHIMANO XT DISC M756 HUBS, and I'm doing the replacement my selft.
    ballbuster
    Reputation: pimpbot's Avatar
    You realize....
    Quote Originally Posted by HTR4EVR
    They are almost the same exact hub, right? QR is slightly different, races are slightly more polished. They shaved a small amout of weight off the hub body... and that is really about it.
    Since you didn't state what happened, If I were to guess, I would say your cones came loose and you rode it that way for a long time, and fried the races in the hub body. If you fried the cups and cones, you can replace them all for like $15. Freehub can be replaced for like $15.
    They are not the same, not in quality. There is a difference when you open a XT from a Deore. There is a reason why you pay less or more. But it is just my opinion based on a bad experiece. The M475 is not as good as the XT.
    ...idios...
    So you're " " and " " because an M475 isn't as "good" and doesn't last as long as an XT? It didn't cross your mind to check more regularly a hub which has no rubber seals on the axle ends? It didn't occur to you that the low-end component might require more regular attention and servicing than a high-end one?
    "The M475 is not as good as the XT."
    And this annoys you? Have a word with yourself, eh?
    Diogenes
    Oct 2003
    Haha of course they aren't as good as XT. I rode those 475s for 2 years never adjusted the cones once. For a budget hub they are great and easy to service if you do have any issues.
    They can be ok for light riding, in my case the the free wheel dye in the first month with rides on flats fire roads and paved roads along the Santa Rosa river. No good. At least they worked good for you. In the positive side I got motivated to enter into wheel building and it has been easier than I though.
    ballbuster
    Don't forget the marketing
    As somebody who has clocked about 3000 miles on a set of those exact XTs, and about 1000 on that same Deore, and have had both apart to service them including servicing both freehubs, I can tell you there is not much difference. There are a few differences, but not nearly as big as you think. Maybe that rubber outer seal doober, but I think my Deore had that on there too. I dunno, that was a few years ago. I could be wrong.
    If you know what the differences are, why don't you share them with us?
    Heck, I got my Deore from a swap meet from somebody who was throwing a wheel out because two spokes were broken and the bearings were seized from misadjustment, neglect and grit. I replaced the cones and balls (to the tune of about $15), replaced two spokes and rode it another 1000 miles before giving it to a friend. He put it on his bike that was ripped off a month later. That thing just wouldn't die.
    My only gripes with Shimano hubs is that they are not terribly stiff (as in they twist in the fork and rear triangle under big side loads), and they are kinda heavy.
    Beotch and moan as you see fit, but I'm telling you, there are zillions of those same exact hubs spinning worry free out there. If you did get a bad one, and it is bad by no fault of your own, it is a complete freak occurrence.
    You still have not mentioned what went wrong with your hub. You said 'They are fry'. Do you mean you fried the bearings? You broke the freehub pawls? The Freehub locked up? Any of those problems are a $15-$20 fix. Oh, and ask your LBS what parts to replace them with. You'll find they use the exact same parts for XT and Deore.
    $15 and spend a little time fixing them is much nicer than spending $35 for a set of new spokes and $45 for each hub... or paying the LBS $50 to lace it up for you.
    The things are dead simple. I'm telling you... you can fix it. Go read Sheldonbrown.com and get an education in bike stuff.
    ballbuster
    Okay...
    ... I just saw your post on your freehub pawls breaking. New freehub - $20, and you can do it yourself with a 10mm allen wrench.
    Did I mention the Deore uses the same exact freehub as the XT? You don't believe me, look it up on the Shimano website.
    Quote Originally Posted by pimpbot
    Yes, you are right, but I got a free hub replacement from Jenson and did not solve the other noises. . I had other problems with the hubs. I already got my XT hubs and I'm redoing the WTB Speed Disc rims with them. But thank you for the suggestion. I have better wheels on my bike any way, I took off the WTB SD out of my bike many months ago, they are going to be my extra set of wheels for my two bikes.
    It is not a problem that is affecting my riding now, I just want to share my displeasure with the hubs in question.
    The berings never ran smoth, always sound crushing inside the hub and funny movement in the free hub.Any way has been good to read all you wrote about the parts, is always nice to here from people with knowledge.
    And maybe I got the bad ones,I never had that experience with shimano hubs before and I have use must of them.
    Needs more cowbell
    Reputation: Ruff's Avatar
    While the guts of both the deore and xt hubs look very similar there is actually differences that effect longevity rather than weight. in the XT you'll find more true bearings, harder cones that are higher polished and the xt does also have better seals. not to mention the xt free hub will take a lot more abuse. the deore isn't a bad hub, however it wont hold up like a xt will. with any loose ball hub you'll need to properly adjust the cones out of the box if you intend for them to last longer than 1 season.
    fan of maple syrup
    Reputation: nuclear_powered's Avatar
    Interestingly enough, I have just handed my rear wheel into the LBS to get rebuilt due to it constantly breaking spokes at the nipple, plus the hub - a HB-M535 - has a bit of play in it (they told me when dropping it off it's probably just the cones and that it needs a bit of adjusting). In any case, the breaking spokes and this hub problem make the only 2 things to go wrong with this wheel.
    However, in order to keep riding while the wheel is getting rebuilt, I got the wheel off my old bike which has the same cassette and rotor, and noticed it's a HB-M475 - the very hub that's the topic of this thread. I rode that bike for 2 years every weekend (aggressive XC) and commuted 2 -3 days a week, and never once had a problem with the hubs - with zero maintenance. I even used to clean it with my high pressure cleaner before being told this wasn't the best thing to do.
    So yeah, no complaints from me for these hubs.
    I'll be interested to see how it goes this weekend on a much beefier full suspension bike.
    Needs more cowbell
    as somebody that regularly works on bikes and orders on QBP the deore and xt free hub bodies are not the same, they are interchangeable however. deore free hub retails for about 20 bucks, xt retails for about 40.
    Do the HB M525 hubs have about the same guts as the M475? I keep reading bad reviews on them but I think that when failure happens it is much more likely to pop up on a review. Who knows how many are out there getting beat to crap without maintenance and surviving fine.
    Any given singletrack!
    Reputation: blue_dragon's Avatar
    Apr 2005
    Well, I had 475 rear hub on both my last bikes and never had problems. The first one lasted 10000 km (6250miles) with one overhaul and then the bike got stolen. Second rear 475 hub is still on my current bike and has around 6000km (3750 miles). I overhauled it last summer. It's a 30min job to open it, clean and put fresh grease. Works perfectly. Don't understand what's the fuss about...
    Apr 2005
    Quote Originally Posted by calvus
    True. It's strange that when something works perfectly people tend not to talk about it. But when it stops working, they are loud as they can be. Read my upper post.
    I changed the hubs my self and my new XTs are running smooth....
    Reputation: santan's Avatar
    these hubs do suck. I need to change out my rear hub.
    So wait, the cheaper M475's are NOT as good as the more expensive XT hubs!?
    Underweight Rider
    Reputation: AznRider's Avatar
    Yes that why they make the more expensive XT? ironic huh.
    I have yet to see ONE single M475 warranty or service issue. A lot are over tightened but not as badly as the hubs used in STA-TRU wheels (blah!).
    For Sale: Cateye Triple Shot, modified with high output emitters!
    bad hub
    okey i agreee with u ... the hub aint good! i've changed mine twice in two months now... Next time i'm buying a better hub!
    Reputation: thomasali's Avatar
    475s are generally awful, we used to sell many many bikes with these hubs, and for customers they are not really a fit and forget item! They seem to develop play very easily, and customers dont notice until its too late...... we had so many gt ruckus, and various other xc bikes back with these hubs knacked.
    bike dork
    Reputation: mtbdee's Avatar
    Jan 2005
    From the OP - "Stay away of this shimano crab".
    Just because your hub has STDs does NOT mean they're lousy. Watch how you treat that axle and balls and you will probably avoid such problems in the future..
    Full disclosure; I sell and repair bikes for a living: http://blackstonebicycles.blogspot.com/
    My front hub is still working great today, but the rear was finished about 3 months after I bought my bike. This was all dry desert riding with no mud or water.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Sorry, but the 475 hubs are garbage. There is no (real) sealing. You have to repack them all the time. On a relatively new rear hub the sleeve that holds the freehub to the hub shell just stripped the threads out of the hub shell, so now the freehub falls off. WTF?? XT hubs actually work pretty well. I would not buy below XT under any circumstances.
    My video techniques can be found in this thread.
    DeForest Stump
    Reputation: Cobretti's Avatar
    May 2005
    Quote Originally Posted by mtbdee
    Shimano crabs are THE WORST! Almost impossible to get rid of
    kevboz
    Where can I get a rebuild kit for these online? I checked with my LBS and they didn't even have the 1/4" bearings. I'd rather just order it online and do it myself.
    Quote Originally Posted by kevboz
    Time to find a new bike shop
    M475 hubs are often described as Deore, but they are not - no rubber seals to keep dirt and water out. The result is that, if used off road, they wear out very quickly - the bearings get noisy and spindles wear loose! I just bought M525s to rebuild my wheels and so i can re-use my spokes. The M525 looks the same as the M475, but do have the rubber seals, not steel ones. I bought my wheels secondhand and were only a few months old. The bearings were rusty, so I replaced them. No more than 100 miles later they are shot again. Conversely, I have other hubs with good seals that have lasted 10 years.
    I contacted Shimano about the confusion over these hub types, but they refused to do anything about the retailers describing these M475s or acknowledge the confusion.
    I really don't understand why Shimano would put their name to a mountain bike hub that is unsuited to typical mountain bike use - offroad.
    There is an easy way to identify these hubs - If it hasn't got "Deore" written on the hub body, it's an M475
    Give M475s a wide berth!
    the UPhill machine
    Reputation: theshore_KING's Avatar
    Sorry to but into the conversation but does anyone know how much the M475 actually weighs?
    - KING of the SHORE
    http://www.yuwie.com/r/10245
    Former Bike Wrench
    I've owned the XT M756, Deore M525, and M475 and I would agree that the M475 is pure rubbish.
    The problem is the seals, or lack there of. Basically, Shimano appears to have put the same lightweight seals as come on their ROAD HUBS. The M475's came stock on a Kona Stinky I owned and had to be repacked after just about every wet ride. Even using a waterproof marine grease was of little help. After two months, I got rid of them and got a wheelset with the M756 and did my standard once a year overhaul. The XT's never blinked at the sight of wet rides with a good marine grease in them. The M525's I owned were also better in the wet with the improved seals, though obviously not as smooth as the XT's.
    It still pisses me off that Kona...a NW company and one that I respect, would put such a hub on their bikes. They'd be better off putting a Formula or Quando with decent seals on their bikes than the M475
    namagomi
    Reputation: electrik's Avatar
    My front hub(m475) lasted one month of salty winter commuting, ball bearings are rusted and race is rusted.. had good marine grease in there also. The trouble is these hubs have only one measly seal which worked about as well as Paris Hilton's chastity belt!
    Anybody know an easy way to add more sealing or a hub i can swap in easily?
    yorkshire mud monkey
    Reputation: sausagedog's Avatar
    here my one cent worth..had the hubs on since i got my cannondale rize that was 1year ago only greased them once well ok not grease, i used vasoline and they have been fine.after the rebuild i did cover everything in vasoline so crap wouldnt get in so maybe thats protected them a bit longer,iam moving on to nuke proof hubs soon see if the bearings on them last.
    as steve said "As long as the rotor/rivets clears the fork, a miss is as good as a mile"
    hipneck
    I was just about to....
    post a question about my hubs ( HB RM 65) but saw this and while reading through it noticed one poster mentioned low end Shimano hubs usually come with too much preload. I just checked mine and the rear is ok but the front is too tight. My question is how long does too much preload take to ruin a hub? I knew when I bought the bike that the hubs were low end and would need regular service but the the preload thing caught me off guard. I have about 400 miles on the bike and if there is any chance that the hub is toast I would take it back to the lbs. Thanks for any help.
    namagomi
    Dear John,
    You must open up the hub using a cone wrench and check for pitting on the cups and cones.
    I'm sorry it has to be this way, but don't worry it takes a while to ruin a hub with too much preload.
    Reputation: socal_jack's Avatar
    Dec 2008
    I wrote a bad review for the M525 hub on MTBR these share guts with the Alivo (m475 mc18 lines) replacement freehub body is the exact same P/N (I also write reviews when I think stuff is really good, like this bike), also mentioned I've never had a problem with XT hubs(7 or 8 of `em at least) doing minimal if any maintenance, my M525 came stock on a GT Peace 29er multi WTB SD AM wheelset(rims are crap also see other reviews) lasted 6-8 months. To get to the point of the mode of failure that I experienced, I believe to be a either a design flaw or a planned obsolescence feature, take your pick. This construction is common to the Shimano line of hubs with 2 pawls yielding 32 points of engagement. Failure occurred pedaling uphill, I heard it, but I could tell something happened as any slowdown or attempt to freewheel resulted in the chainwrap(I was now riding a 2x9 fixie). I've got the new freehub in but not installed and just took the failed unit apart tonight to examine it. Before getting to the pics it should be noted that the freehub body is 2 pawls but they are at a spacing of roughly 120 degrees not 180 like you might expect, but Shimano has been doing it like this forever(looks quite similar to an old M550 BITD). Seems like it would lead to unbalanced loading to one side internally which I think leads to eventual problems, especially if the bearing preload does loosen up. I don't believe dirt intrusion played any factor in the failure, everything was clean inside what little seals there are, held. The failure I experienced seems to be rather common in the reviews.
    New freehub body $26, whole new hub $22 same place, go figure. Anyway wheelset will be demoted to very light trail duty after freehub replaced and rims trued. Disclaimer, I'm Clyde weight but this bike is rigid and doesn't get jumped, rims can't take even minimal rock garden stuff though.
    Roll tape!
    Shot 1, broken lower pawl half that most likely lead to the other damage, the 2 halves of the pawl are connected under the retainer, damage also to the freehub body at the back of the lower broken pawl half.
    Shot 2, chunk of freehub body broken off between the 2 pawls
    Shot 3 other side of freehub, this is not cut out the same as the other 2 pockets, probably can't take a pawl
    Shot 4 Shot of beatup engagement points
    Dec 2008
    Meant to add here's a link to the Shimano freehub interchangeabilty chart, very handy
    http://bike.shimano.com/publish/cont...ngeability.pdf
    ive had mega pitting on the front and rear has well ermm died now but replaced with the nuke proof ones now so bye bye shimano.
    Quote Originally Posted by Buck268
    I bought a set of M475s wrapped by WTB speed discs which were wrapped in a KHS Flagstaff (full susp. 29er). Picked the bike up on Thursday, rode 7miles, took it out on Friday and rode 3 miles. Now I am without a bike (for about a week) because these hubs broke after about 10 miles of trail! This really sucks because after the crappy winter we just endured here in the mid-atlantic, I am missing out on some of the best (only) good riding weather in nearly 4 months!!!!
    Of course the warranty is taking care of everything, but who wants to go thru the waiting? I am in the process of finding a new set of hubs to replace these - hopefully, the replacement will last longer than 10 miles because I spent what i had on the bike. Should I have serviced the hubs more often
    P=DAL, P=DAL, P=DAL!
    Two in a row!
    Today marks the breakage of my second M475 hub - IN UNDER 30 MILES TOTAL!!! The first one broke on my second ride, the second one broke after another 3 rides. I am in the process of shopping for a replacement wheelset - which is NOT what I intended on when I bought this bike!!! This is a KHS Flagstaff and I suppose KHS decided to save a butt load of money by buying up shimano's most defective hub.....customers, schmustomers!!!! And it really blows to sit thru beautiful weekends with your bike sitting in a shop waiting for a replacement part; being warranted doesn't make it much better.
    Where can you get parts (cones & cups) for the M475 Front HUB with the 10mm Axle?
    Several LBS cannot locate cones. Trying to fix up commuter bike without buying a new front wheel.
    OR can I replace cones and cups with DEORE Cones, cups, seals? Lot of work but it would save otherwise good wheel.
    US or Canada sources parts please
    Reputation: kiwi_matt's Avatar
    Another one here to say those hubs are fine. I've clocked up 1000's of k's on them and they've run problem free. The only time i've had them apart is to degrease and repack the bearings.
    Old Dirt Road Tourist
    Reputation: hoboroadie's Avatar
    Generic Bits
    Shoestring would be an optimistic description of my bicycle budget. I was bidding on another ebay rim and came across this thread; I went out to check my fleet, and except for one pair of FH-M750 Deores and an RO85 Stealth Infiltration wheel, all my hubs are M475 or worse. I think maybe 80% of the time when I get a used wheel from Craigslist or wherever, it's never had the cones properly adjusted, and they're too tight. Once I get that straightened out, I just run'em, often not even repacking the grease, and I don't have any complaints. Where I draw the line is with cheap dimestore hubs with threads so poorly cut that the adjustment shifts when they're locknutted, and I work around that when I have to. I've seen bad parts come from manufacturers, so that can happen, but I suspect most problems are assembler error. I hear some complaints about seals, well I guess maybe I don't bury my axles in mud deep enough to have problems there; I leave my fleet out in the rain &c. and just have a little extra grease boogered around the outside and that seems to have taken care of that. Offtopic, I hear complaints regarding rim strength, and there again my mostly generic and used-up bits hold up just fine as well. Jumps and drops and roots and cobbles mostly cause problems for badly tuned wheels or poor technique. I don't do extreme so much now, but back in the Evel Knievel days I learned how to land a bike without crushing things, and I've noticed that not everyone else did, so when the whingeing starts I take it with a grain of salt. I can appreciate $500+ wheels as much as anyone, but actually where I start my upgrade is at the chain and cassette, because the shifting improvement is most noticeable. YMMV
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    OK first off... the 475 hubs are NOT Deore level, they're not any named group level. They belong to the non-named series parts which have a model code level and that's it. Technically they're closer to Alivio than to the Deore groups.The Deore hubs are the 525 ones. Second comparing to or expecting XT performance from a hub that costs less than 1/3 as much is idiotic at best.
    I don't post to generate business for myself or make like I'm better than sliced bread
    I need some help because my Shimano M475 that I had on my Gary Fisher Marlin Disc have now been replaced by Shimano HB RM65s. The issue I have is that the quick release on my M475 axle is not the same as the RM65 one!? I have a Rock Shox Dart 3 front fork on it. I am not sure...it seems the only way to get it to work is to tighten the axle. I also don't have the clearance to spin the tightening bar...it keeps hitting the fork. help?
    Skewers
    Use the thumbnut on the other side to tighten it up, and you'll want to pick an angle where the lever will find clearance when you clamp down the skewer. Usually I hear to have the lever wide open, then screw down the thumbnut until it contacts the forks. I find that I prefer to have the lever out perpendicular to the wheel, 90 degrees from tight and then clamp it after it touches, but I don't ride extreme. This is a very critical safety issue, laws were even passed back in the '70s as I remember. If you aren't sure what you're doing, get someone local to help. Someone at your LBS would probably spare a minute to get you straight.
    thanks for the note Hobo. I just went to the LBS and picked up a Clix axle instead so i can pop it in and out and also have the ability to turn and tighten 360 degrees.
    Fossil
    Reputation: mtmiller's Avatar
    Nov 2006
    Lost a Shimano M475 rear hub on my son's bike yday. This follows another M475 failure and two M525 failures on neighbors' bikes. All bikes were 2009 and 2010 and have followed the same failure pattern: wheel OK when new, after a few miles can see wheel shaking, remove wheel to find loose locknuts, gently adjust cones and tighten locknuts, hub bearings fail <100 miles later. Not sure what is wrong with them... I've been adjusting loose ball bearings for many many years now with no other issues on other brands. Even have a wheelset from a 2006 model year bike that uses M475s and they've been fine after 100s of miles.
    OK, mild beeching over... off to search for a new hub or new wheelset.
    DB Dirt Club
    DBs on Dirt since 2010
    Am I right in thinking Deore and XT are the same apart from XT has holes milled out of flanges to save weight, a different finish (not better), an extra seal on the freehub side, and a better freehub (which can be fitted to the Deore as an upgrade)?
    Quote Originally Posted by 9speed View Post
    Not exactly sure about the Deore and the XT.
    For the M475 The Cones are different. Shimano USA and Wheels manufacturing don't make cones for the M475 front Hub. The Steel Bearing races are probably different. The metal shields that cover the bearings are different. These races and shields can be pried or pressed out. This allows you to rebuild the Hub with parts from another shimano Model.
    I rebuilt a 475 front hub with parts from a old rim brake LX Hub. I used the races, shield, cones, seals and axle from the old LX Hub. Plenty of old Shimano hubs around with parts that will work.
    b1_
    b1_ is offline
    Quote Originally Posted by socal_jack View Post
    hxxp://bike.shimano.com......Interchangeability.pdf
    How do you read this interchangeability chart? I have a Shimano 8S Parallax FH-MC18 hub. The FH-MC18 freehub body has started to spin without grab off-and-on. What other freehub bodies would work here - I wouldn't mind a bit of an upgrade?
    Also, I'm no expert, but I could swear that the freehub body crapped out because I over-tightened the cassette when I installed it. I've only just started to get into fixing my bike myself. I needed to replace my drive chain. I really tightened the cassette on there. It's too much of a coincidence that my freehub, which had been going for almost a decade, craps out two rides after my amateurish attempt to at do-it-yourself. Does this sound right? How could an over-tightened cassette damage the freehub body?
    I've been used M475 for awhile and didn't find any issue eventhough I use it quite hard and a little abused..
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Regarding FH-M756 hubs that have been mentioned in this thread, do keep in mind that there are 2 versions of this hub, and they look alike at first sight. There is the basic 756, that has decent rubber seals and flanged locknuts, and the 756A, that has no rubber seals and generic 6-sided locknuts.
    I suspect that quality of races is also worse on 756A.
    As for 475 hubs, I know a very experienced bikepacker (he also runs a repair shop) who chose the hubs deliberately for his off road touring 26" bike. His tactic is to overhaul them in the field after every serious contact with water (like heavy rains and stream crossings).
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
    Reputation: stingray's Avatar
    Mar 2014
    Quote Originally Posted by pimpbot View Post
    Where can you get the cups? The Shimano M475 diagram doesn't show them.
    http://www.shimano.com/media/techdoc...9830647979.pdf
    meow, meow.
    Quote Originally Posted by J. Random Psycho View Post
    Since this thread has been revived, I have to update this. That's obsolete now as the production of FH-M756 has apparently ceased, and FH-M756A has been updated with contact seals and is now known as "Shimano 756 rear hub". There's now nothing wrong with 756A inasmuch as it applies to Shimano hubs.
    As for 475 hubs, I know a very experienced bikepacker (he also runs a repair shop) who chose the hubs deliberately for his off road touring 26" bike. ...
    Do you know anything about why he did that choice, and didn't want hubs with better seals? I can't really see any functional advantages? It seems like he was thinking something like "OK, they're not good but cheap and if I take them apart every time they get wet and drain them and maybe re-grease them, they won't break and work good enough...".
    If you fried the cups and cones, you can replace them all for like $15. ...
    Quote Originally Posted by stingray View Post
    As far as I know, it has never ever been possible to buy replacement cups for any Shimano hub. Which is a shame. Shimano hubs are just to throw away if the cups get worn or pitted. The cones get pitted first of course, and many times the cups looks ok even when the cones have worn badly, but I have thrown away hundreds of Shimano hubs with damaged cups.
    (And when hubs and bearings are discussed, I would like to take opportunity to direct people to Park Tool's wonderful instructions on adjusting cup and cone bearings. They have an ingenious method of clamping one side of the wheel on the outer side of the frame and adjusting on the free side of the hub - with some training you get a perfect adjustment with compensation for the quick release pressure fast and easy every time.
    Cup and cone bearings can work very very well and last for a long time - decades for some - but only if they are adjusted properly.
    Park Tool Co. ParkTool Blog Hub Overhaul and Adjustment
    Wheel Bearing adjustment by Jobst Brandt)
    meow, meow.
    Quote Originally Posted by Naugas View Post
    Yes, exactly because he can overhaul them quickly and anywhere, and they run great in between water encounters. Cheap too. I'd run something like FH-M529 myself these days if I chose to go with gears. Would replace the axle with a longer one to use cap nuts (less traumatizing potential than axle ends protruding past plain nuts) for retention though. Not a fan of the axle being clamped longitudinally in between dropouts. I would also have ground away the knurling on locknut faces so as to get easily repeatable brake rotor positioning inside caliper. The bit of OLD thus lost I'd compensate with an accordingly chosen DIN 988 washer.
    Given the price of these hubs one can buy 1-2 more for spare parts, including the freehubs..
    Over the years I have heard 1-2 reports of cups replaced on cup and cone hubs not unlike how one goes about replacing cartridge bearings. I'm yet to try it myself, have a new 756 hub shell with NDS cup in it at hand especially for this.
    Oh I've been following this procedure for years with very nice results. Used to receive critique for that too, in a rude form. But I still adjust them like this. )
    Mar 2014
    My wife and I have commuted for ten years on M475 hubs. They were original equipment on our Marin Point Reyes. No attention has been required until now -- two of the four hubs has started to feel "crunchy" when spun. Rather than hunt for replacement cones and cups, we've decided to upgrade to M756 hubs. I was glad to read here the M756 is drop-in compatible with the M475.
Members who have read this thread: 11
