Results 1 to 5 of 5
    will Specialites TA chainrings work with xtr m760 cranks?
    will these chainrings https://www.starbike.com/php/suchen....s+TA&q=chinook work with the xtr m960. I'll be running 2x9 so I won't need the outer ring. If not, what other options do I have?
    Thanks.
    Quote Originally Posted by blantonator
    ...... the xtr m760. ........
    Thanks.
    Can you clarify this? To my knowledge, the XTR line is 9xx and the XT line is 7xx. So either XTR 960 or XT 760.
    Anyway, here is a thread at the WW forum showing several setups (XTR 970 + XT 760).
    http://weightweenies.starbike.com/fo...hp?f=1&t=53945
    sorry xtr 960
    IIRC, the 960 has a 102mm BCD (outer/middle) and 64mm BDC (granny), which kind of limits your options. The link you gave are for 104mm and 64mm BCD's. The 64mm can be used to replace the granny, but the 104's won't work for your 2nd ring.
    I'm not too familiar with the 960's, maybe someone else will chime in
    ups and downs
    Specialty TA list a 102mm 32T ring and 146mm 44T ring in the GAMME C116 series
    http://www.specialites-ta.com/produi...u-2008-VTT.pdf
    Blackspire make an XTR 960 ring set, and you really want to use them as a set to get the shift ramps sync'd.
    http://www.blackspire.com/qs/product/83/5948/263226/0/0
