Results 1 to 5 of 5
    Reputation: h2bmess's Avatar
    upgrade help..simple answer i promise...
    ok as u guys know my 8 speed x-5 derailleur broke. so i orderd these parts
    Shimano SLX M670 Shadow 10 Speed Rear Mech
    Shimano XT M780 10 Speed Trigger Shifter
    Shimano SLX HG81 10 Speed MTB Cassette
    Shimano Ultegra 6600 10 Speed Chain
    i already had upgraded my crankset to:
    Shimano SLX M665 Crankset w/ Bash Guard 8/9 Speed
    now the mech at the LBS says i might need a chainring...??? any idea what i should get thanks!!
    Fat-tired Roadie
    Nov 2007
    Try the new chain on the existing chainrings. See if it will fit over the teeth and also if it can fall between rings.
    My expectation is that your existing crank is fine. If it's not, you have a few options, depending on what the problem is.
    thanks,
    Jan 2009
    You will be fine as is. I've got a M660 crank modded to 2x, ie. M665-ish running 10 speed w/o issue.
    thanks guys, guy at the LBS has me freking a lil..
  1. Replies: 5
    Last Post: 02-08-2014, 07:49 AM
  2. simple forks for simple-minded riders
    By mack_turtle in forum Shocks and Suspension
    Last Post: 09-09-2013, 02:14 PM
  3. This isn't a RANT...I promise!
    By icegeek in forum Colorado - Front Range
    Last Post: 04-25-2012, 05:05 PM
  4. Answer this upgrade question
    By Pininfarina599 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2011, 09:16 AM
  5. looking for deal on answer pro taper and answer dh one stem
    By david8613 in forum Where are the Best Deals?
    Last Post: 06-11-2011, 11:25 AM
