Results 1 to 3 of 3
    Mar 2006
    Small chainring for M952 Crank (4 bolt)
    I've worn out the small chain-ring on my M952 4-bolt crank again, and can't find a new one anywhere.
    If you are familiar with this crank you know it will accept only the original Shimano chain-rings. Or, you could pop for an aftermarket spline and all new aftermarket chain-rings, which I'm not about to do.
    This is a bulletproof Crank, and I see no reason not to keep using it until it breaks, which will be never.
    I just need a source for new small chain-rings (24t). Does anyone have any ideas?
    Beyond Bikes says Shimano doesn't make them anymore.
    Mtbr Forum Sponsor - Homebrewed Components
    Quote Originally Posted by mtnmasher
    I can make one for ya. shoot me an email.
    Reputation: flamencohead's Avatar
    Dec 2009
    Middleburn makes a replacement spider
    If that does not work out, Middleburn makes a spider adapter for the m952. You would need to replace all three rings. I have the same situation and I'm waiting for parts now. You can find more info and links here:
    http://flamencohead.com/flamencohead...52_chainrings/
    Robert
