Decided I'd give it a whirl (Since I'm waiting for my Niner frame to get here).
It turned out pretty sweet IMO. I used caustic soda and water. Scotch Brite pad, and Mothers aluminum and mag polish, and a Mothers ball on the drill. Took under an hour. I did NO sanding.
Don't really know how silver cranks will look on my new white Air 9, so I may sell em.
I also de-ano'd and polished my XTR cranks while I was working on another polishing project, but I did wet sand. This was about 3 hours worth of elbow grease, 400, 600, 800, 1000 grit plus jewelers rouge plus polish to finish it off.
I think the SLX cranks look better than XT or XTR, whether anodized or not. I've also heard that they are just as light -- the main weight savings in the more expensive cranks is in the chainrings. Those polished silver ones look great, and silver looks good on any color bike.
You could spray a clear coat on them to help keep them shiny. They'll eventually get scuffed up and oxidized anyway, but a clear coat will delay that somewhat.
aware this has been covered a bunch, but just bent a chainring and while am waiting for new Blackspire stuff thought I'd give this a shot...before I dunk my M615 Deore in a bucket, are we really sure the new '14 cranks aren't just painted They do not appear to anodized...maybe the drain cleaner will remove either The spider appears to be finished differently like maybe powdercoat at any rate, if anybody has any horror stories, please share
Thanks for the tip, Addam. I did the same with my SLX cranks. I found some Roebic brand heavy duty drain crystals (100% sodium hydroxide) at Lowe's and slowly stirred 4 tablespoons into a gallon of lukewarm water (not hot, not cold). I stirred the solution with a wooden dowel and added the crank arms (sans all hardware). Nothing seemed to happen for the first 1-2 minutes, so I added a 5th TBSP, probably unnecessary, because then it started to bubble and fizz... you could see some kind of chemical reaction beginning. I carefully stirred the parts and immediately the wooden dowel was literally wiping the gray annodizing off the cranks to the bare metal !!! WOW, this stuff works FAST!!
After 5 minutes I removed the crank arms, let the excess solution drip off (there was literally smoke coming off the parts as I suspended them... ) then I placed in a smaller rinsing container, where I rinsed the parts for a few minutes in warm water. Then I wire-brushed off the annodizing... it came off like it was nothing!!! In a few minutes the annodizing was GONE. I did the same for the other crank, and rinsed everything thoroughly. Next I sanded with a fresh Scotchbrite pad, which produced a darkish residue, but then polished into a nice luster (like brushed aluminum).
Next I buffed on my bench grinder using a cotton wheel and yellow all-purpose rouge. This put a mirror like finish on it. Finally I polished with Mothers Mag cleaner (presoaked pads). The whole job took about an hour. Just be really careful with the caustic soda... Make sure to wear sealed safety goggles and chemical gloves, and slowly add the CRYSTALS TO THE WATER, NOT the other way around. Avoid splashing... If you follow a few safety rules, it's really simple... but get this stuff on you or your clothes and it's nasty.... I read lots of safety stuff on it before attempting it.
Finally I neutralized the bath with a few tablespoons of vinegar when I was finished, after which a poured it down the drain of my utility sink.
sorry to resurrect this, but how does the shine hold up?
Im thinking about doing this to my slx cranks, but im worried that after a few months they will start to oxidize. What were your experiences with this? how did you prevent it if needed?
I just did mine as well. Powdered drain clog remover + water. I just scotchbrited it and haven't decided if I want it polished. Took under 2 hours to do. How are your de-anodized cranks holding up?
Love the polished. I had a little accident on my very first ride with my SLX crank, I think its time to take it off the bike, sand the scratches out and polish it up myself! Definitely going to do it this winter if I don't get to it soon
Could I do the same as the first post does on the SLX cranks using the "caustic soda and water Scotch Brite pad, and Mothers aluminum and mag polish" method and get as higher shine on the bars?
Yup, they look sweet :thumbsup: Got me thinking maybe I'll do the same to my old M760 XTs I have, that are partially polished due to heal rub. Polished cranks before, but did it the hard way using oven cleaner, steel wool and sand paper, this seems a lot easier with great results.
Not sure if these are ano-d or painted but was going to try the procedure mentioned in this thread. They're Deore cranks.
UPDATE:
Bloody-hell. They are painted, rather powder coated. I purchased a can of aerosol paint stripper from Home Depot after trying the drain cleaner approach. DC won't touch the powder coat at all. This was basically an all-day project mostly just letting the paint stripper do it's thing. Near the end I used a barbecue brush and stainless steel Scotch-Brite pads to get the remaining paint/powdercoat off. It took a fair amount of elbow grease and patience to work into the nooks and crannies to chase most the paint. I couldn't get all of it and I really don't care at this point. On a positive note, the stainless SB pads actually leave a pretty decent polished surface behind, enough that I won't need to wet sand the cranks. Anyway, thanks to everyone who contributed to this thread. Here the are:
Tried googling, no results. Then I thought, allright, maybe there is some newer version of it. To no avail. Then I realized I shouldn't have skipped those dictionary links google put in the first place.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
