Page 1 of 3 123 LastLast
Results 1 to 25 of 60
    Shimano's answer to SRAM's 1x11
    Anybody know if shimano is coming up with something inovative as an answer to the already well acepted 1x11?? Maybe oval rings, 1x?? ...
    Reputation: shanem's Avatar
    I don't know if they have anything planned but I sure hope they do. I'm not a fa of SRAM stuff but that 1x11 looks right up my alley, I just wish it was Shimano.
    Reputation: Surfas's Avatar
    I like the idea but the cassette with a 42 aluminium tooth ... and a carbon crank ...
    I 'd like Shimano XTR crank with 30, 32, 28 and more rings, XTR cassette 13-42 for a normal freehub and that kill Sram XX
    I agree. I see no need for a 10 tooth cog with the SRAM setup. I currently run a 36/28 up front with an 11-36 rear cassette. I can get away without even using the 28 up front most of the time. If Shimano were to make an 11-42 or a 12-42 rear 11 speed cassette I'd probably run just the 36 or even a 38 up front. The best part about the SRAM setup I think is the larger teeth on the front chainrings to eliminate the need for a chain guide. I just hope Shimano can come up with something similar.
    At front I need a 32 or 30 depending the trail for a 42 rear. For me 13-42 on the back can resolve the freehub problem
    Reputation: limba's Avatar
    I'd LOVE to see this happen. I'd buy it.
    Shimano's answer will the opposite XTR Di2. Just a hunch based on what we have already seen from Shimano.
    Dec 2009
    I think shimano goes to 9t cassette like a capreo groupset... Using a small chainring (26t to 30t) with a 9-34t or 9-36t cassette, short cage derailleur, short chain and overall is more light than xx1 with equipared gear ratios... Hope is to launch 9-36t cassette... Shimano probably is in the same ballad...
    Send from Tapatalk via GalaxyTab
    Apparently a 9 tooth cog is hard to pedal. You can read about it here.
    SRAM XX1: Component Development And Details | Cyclingnews.com
    Dec 2009
    I see this article after i posted... I understood the reason for don't go to 9t... Maybe new chain design can be the best solution for future.....
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Quote Originally Posted by shanem View Post
    plus one
    Better to have and not need it, than to need it and not have it.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by mtbpri View Post
    Why do you think XX1 is well excepted? Because theirs 5 companies making hubs for it? I see this as being a major hurdle for consumers. I hope Shimano comes out with a system that works on a normal freehub body and kills this silly Sram driver setup that's going to struggle to gain acceptance from the industry.
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
    There's a lot more than 5 companies compatible with xx1. The only ones I can think of that aren't compatible are Shimano (duh) and King.
    Plays with tools
    Quote Originally Posted by limba View Post
    It is more than 5, maybe 1/3 of the hub companies plan to be compatible by the beginning of the season. That doesn't change the fact that the driver and the 10 tooth cog that dictated it's adoption isn't necessary. An 11-42 would have been just as good for everybody and wouldn't have created the mess.
    Yeah, but it wouldn't be just as good for everybody. Everybody isn't you, everybody isn't me. A 32 chain ring and a 11 cog won't work for me. A 34/11 won't work either. Sram tried it's best to give the customer the biggest gear range they could with one chain ring and a big ass cassette.
    At least all the big companies, except the two I mentioned are on board. Is there a hub company that you absolutely need that's not compatible?
    Personally I don't like proprietary anything. I don't even like SRAM but the driver thing isn't that big of a deal.
    Quote Originally Posted by customfab View Post
    42-10 gives you 10% more range than 42-11. That's not insignificant. Most people who would be willing to pony up the $$$ necessary for this are likely running hubs which have an XX1 freehub available. The added cost of the new freehub is pretty small compared to the entire group, so why not? It's hardly a mess IMHO. I'd buy this in a heartbeat if it was available in X7 trim and not think twice about the cost of a hub body for my Hopes.
    Plays with tools
    Quote Originally Posted by car_nut View Post
    Or you could go 44-11, with a bigger front ring and keep the existing free hub format. There are 3 factors in calculating gear inches, the cassette is one of them. Going from a 32 to a 33 or 34 isn't going to hurt anybody.
    Yeah but then you need an even bigger cassette cog to get the low gear you want. It's a compromise no matter what you do.
    Well, you'd need 46-11 to equal the range of 42-10. You'd also need a longer cage to take up the extra chain. The other cogs would also need to be larger, making it heavier.
    Again, I don't see what the big deal is about buying a new freehub body. If you HAD to use a SRAM hub, then I'd agree. If you're OK with putting down almost $1k for this drivetrain, then you probably aren't going to complain about another $90 for a freehub.
    I also like this idea of 1x 10 or 11. I dont like it being SRAM or requiring a new freehub body. i've not had success with SRAM drivetrain in the past.
    I agree what would be great is if Shimano made the 11spd cassette 11 or 12 to 42 or 44, kept the same freehub body width, and dropped the complicated unidirectional chain with special pins and differing pins on each link. I hate their chains, just not trail-chaos-in-the-dark fix friendly.
    The other thing is that rear deraileur will have to be uber long cage. Back to snags and hitting rocks.
    We Ride In God's Country!
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by myitch View Post
    I have spent the coin to give XX1 a go, But yes I see a market for a 42-11 to go on the std free hub.
    Mybe there is a X01 group set coming that will do that, I hope so.
    Attached Thumbnails Attached Thumbnails Shimano's answer to SRAM's 1x11-green-rdo-xx-001.jpg
    Quote Originally Posted by muzzanic View Post
    So, how do you like it? Did you have experience on say, a 2x10 with 11-36 rear and 24-36 front? That's what I'd like to find out. I'm more interested in the comparison with the XX1 42t-32 vs Shimano 36-36 for climbing.
    Carbon & Ti rule
    The bike is new so i will have a better idea in a week, But it feels real good.
    I have a 26/39 2x10 11-36 on my other bike that is all but the same so I will get some good back to back.
    My other bike has 36/22 2x10 11-36
    Attached Thumbnails Attached Thumbnails Shimano's answer to SRAM's 1x11-trip-033.jpg
    Cool.
    I meant 24 or 22 front and 36 rear to XX1 32 or 34 front to 42 rear. Just by looking on paper the gear seems like it would be quite low for climbing, but IDK. We anxiously await your report
    32 ring with a 42 cog = 1.6
    24 ring with a 36 cog = 1.4
    22 ring with a 36 cog = 1.3
    So if you need the 22/36 the 1x11 won't work or you have to suffer on those climbs. Basically you lose a gear.
Hot Deals
Contests
Latest Mountain Bike Articles
