Page 5 of 5 FirstFirst 12345
Results 401 to 465 of 465
  1. #401
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by Shredman69 View Post
    I have a triple, with an 11-40 General Lee and an XX rear Derailleur and it shifts great. No problems. Chain growth is not an issue either unless I was to run small small which I would never do anyway.
    I wasn't talking about a 40 tooth.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
  2. #402
    Reputation: Shredman69's Avatar
    I know, but it's close enough.
    13 Intense Uzzi
    06 Santa Cruz Nomad
    00 Santa Cruz Bullit
    26er's for life!!!
  3. #403
    Sep 2012
    Does anyone know if the new xtr is getting officially announced this week??
  4. #404
    Jun 2010
    Quote Originally Posted by YodaForce View Post
    Officially announced tomorrow, there's new info and pics in the drivetrain section of this website though..
  5. #405
    Reputation: MrPretty's Avatar
    Feb 2012
    Here it is, in its mechanical form at least.
    First look: Shimano XTR M9000 ? All New 1x, 2x and 3x 11-Speed Groups
  6. #406
    Looks ok, but I still want the Leonardi 10sp 942.
    13 Intense Uzzi
    06 Santa Cruz Nomad
    26er's for life!!!
  7. #407
    Jun 2005
    Current crank still looks WAY better than the next gen, aesthetically speaking.
  8. #408
    Reputation: pharmaboy's Avatar
    So no change to freehub, and no change to dish, and with front derailleur clearance with new derailleur
    Pretty much all the stuff that people complained about earlier in the thread has gone .
    Could be a great thing for frame designers , especially as lower groups will surely follow the FD design ( it doesn't seem intrinsically expensive)
  9. #409
    Nov 2012
    I have no problem saying that using the same hub is definitely nice but if getting a new wheel set anyways, its easy enough to get a hub where you can swap out the required hub body/driver. But the other turnoff for me is not wanting to pay xtr type money for a 1x drive train. I'll be curious as to how long it takes them to go 11 speed down the line. They just now are going 11 speed on the 105 line on the road side of things
    Sent from my XT1080 using Tapatalk
  10. #410
    Nov 2012
    Re: Shimano's answer to SRAM's 1x11
    Quote Originally Posted by cpfitness View Post
    I have no problem saying that using the same hub is definitely nice but if getting a new wheel set anyways, its easy enough to get a hub where you can swap out the required hub body/driver. But the other turnoff for me is not wanting to pay xtr type money for a 1x drive train. I'll be curious as to how long it takes them to go 11 speed down the line. They just now are going 11 speed on the 105 line on the road side of things. Spacing between gears is important to me which is why I probably won't bother doing an add on 42 cog to a 10spd cassette but I'm not trying to spend $200 on an xtr cassette, $125 on a rear xtr shifter and $225 on a new xtr rd. Wouldn't it be nice if I could just take my existing xt shadow+ rd and have it work with the new 11 SPD shifter? If that is the case, then they may get me to buy a cassette and new shifter
  11. #411
    This groupo looks to me like it's designed to go down the line.
    When you look at xx1- that cassettte is a work of art and ain't getting any cheaper any time soon. Shimano have gone with std design with nothing at looks hard to produce, nor hard for manufacturers to replicate (eg freehub body)
    The big selling groupo for shimano I think is XT, they use xtr for perceived value, and build sales into XT by making them close. Id almost guarantee next year will see xt 11 speed
  12. #412
    Nov 2012
    You are probably right in that. Regarding xx1, many people balk at the cost of the cassette but I haven't heard much talk of people wearing g it out. For one, in a 1x system you end up spreading the use around a whole lot more. I wouldn't mind paying big bucks for that cassette because it does give significant added range that shimano doesn't.
  13. #413
    Jun 2005
    Not to go too far off the rails, but is it possible to extend the range of the current XTR 11-36 10-spd cassette to a 13-40?
    Could you remove the 11T cog, put a lock ring on the 13T, then add a 40 on the low side? That would make a 13-40 10 speed with normal gaps, which I could totally live with.
  14. #414
    Nov 2012
    Ive heard of it being done with a modified lock ring.
  15. #415
    13-40 has less range than 11-36.
  16. #416
    Jun 2005
    Quote Originally Posted by spsoon View Post
    Fine...but I'm looking for more low end, willing to sacrifice the high end. Just wondering if it's possible.
    Heck, I've been exclusively on a 29er singlespeed for the past several years.
  17. #417
    Then wouldn't it be easier to change the chainring, or are you already on a smaller one?
  18. #418
    Jun 2005
    Well, my front-runner comes stock as a 2x10 setup with a 38-26, but for local riding, I'd make it a 1x10 with a 32. On those rare occasions I go to the mountains, I'd put the front shifter & mech back on with the two chainrings.
    Converting the 11-36 to a 13-40 may not be worthwhile, I admit...just wondering if it's an option.
  19. #419
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    There are side effects to putting a smaller single ring on the front. Specifically more pedal feedback and more chain drops if no retention device.
    Sent from my LG-LS995 using Tapatalk
  20. #420
    Quote Originally Posted by dje31 View Post
    Enjoy the read 11-42T conversion: OneUp vs. Wolf Tooth
    I even have a Token 12t lock ring if you end up doing this.
    I have a 42t Wolftooth, but the chain line just isn't going to work out for me. So if you order a 40t and want the lock ring let me know.
    OG Ripley v2
    Carver 420 TI
  21. #421
    XTR Di2 Derailleurs
    Shimano's answer to SRAM's 1x11-le_derailleur_arriere_du_groupe_shimano_xtr_di2.jpg
  22. #422
  23. #423
    So awesome !
  24. #424
    So ugly!!
  25. #425
    Cleavage Of The Tetons
    So expensive!
    "We LOVE cows! They make trails for us.....
    And then we eat them."
  26. #426
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by FastBanana View Post
    Depending on the suspension design anyway. Some designs are less affected by chainring sizes than others. Single pivot bikes are pretty particular though.
    Quote Originally Posted by dgw7000 View Post
    So ugly!!
    We've seen a lot worse in recent years.
    Quote Originally Posted by rideit View Post
    So expensive!
    It's Di2, did you expect it to be affordable? It's in line with what they charge for Di2 on the road side of things.
  27. #427
    Reputation: SLIP TIP's Avatar
    Jan 2013
    Cant wait, my order is in. 26/36. Not only do Shimano design things to work well and last, its priced way better than SRAM. a new casette for SRAM xx1 is .....? take a morgage.
    never mind the fact that you have to buy a new castette mount for your hub. they have had the monopoly for some time, they have taken the piss now they going to get the feel for competition. the OEM side is surly going to side on the cheaper option.
    Supporting the Burry Gap.
  28. #428
    Nov 2012
    Quote Originally Posted by SLIP TIP View Post
    people want 1x drivetrains. That's why xx1 blows this out of the water. The SRAM hub driver is only an extra 80 bucks and I that's what it takes to get a 10t cog, so be it. People are more interested in adequate range then electronic shifting. The one saving grace of this shimano system is the electronic version let's you program the shifting of both the front and rear so you can sort of have the feel of a 1x with all the range
  29. #429
    Reputation: Davide's Avatar
    Well actually One Chain Ring will always have less range than a dual, and when you have a system that operates a dual or triple with a single shifter, as Di2 does, I am not so sure going single makes much sense (unless you are a pro). And Di2 blows everything else out of the water in terms of ergonomics and shifting performance ... in its first race it has already won a WC event.
    Give it 5 years and we will all be on Di2 or similar and I think nobody will even remember XX1.
  30. #430
    Some people want 1x drivetrains. People who actually ride up mountains need a bigger gear spread.
  31. #431
    Nov 2012
    Of course 1 chain ring will have less range but SRAM has already shown us that a very realistic usable range can be had with a single ring without sacrificing top or bottom end. This is a bit of a failure in that regard. Also, the technology doesn't trickle down to reasonable price points fast enough so in 5 years you will see very few using di2
  32. #432
    IMO both 1x and 2x have their benefits. It's not one size fits all. 1x is simpler and lighter, with no exposure to mis-shifting in the front. 2x allows a wider range and the ability to keep gear ratio jumps close; it also allows you to make a large gear ratio change with a single front shift. I would be more likely to put a 2x on a bike that sees a lot of time in the high mountains, and a 1x in terrain where extended climbs aren't common place.
    On the road there's no question. I'd opt for a 2x any day. Close gear ratio jumps make a much bigger difference in that application. Try a fast group ride or race with 4 tooth jumps between each shift... assuming you aren't a lot stronger than the rest of the group it's either going to be painful or you're likely getting dropped on big sudden accelerations. There's a reason people sacrifice range on the road to get 1 tooth jumps between most shifts.
    I'm just happy to see evolution on both single and double drivetrains. I don't plan on buying XTR di2, but may change my tune in another year or two once it trickles down to the XT level and has the kinks worked out. Wireless would also be a bonus, assuming batteries aren't extremely cumbersome/needy.
  33. #433
    Quote Originally Posted by tiflow_21 View Post
    I'm just happy to see evolution on both the single and double drivetrains. I don't plan on buying XTR di2, but may change my tune in another year or two once it trickles down to the XT level and has the kinks worked out. Wireless would also be a bonus, assuming batteries aren't extremely cumbersome/needy.
    I had to go 1x because of my new frame. I'll admit it's kicking my ass. We don't have extended climbs, but we do have rolling hills with quick ups and I miss the FD dump for those.
    OG Ripley v2
    Carver 420 TI
  34. #434
    Jan 2013
    1x seams to be a weight thing and quiet honestly unless ur on it every day. Pro style, it wouldn't work for me. We deal with serious hills on the south coast. Burry Stander country. 2 x is great for me. However I would love the weight saving of the 1x. SRAM is going to take a hell of a beating. XTR is too good and BMC, trek and giant put up a good show this weekend.
  35. #435
    Reputation: bigfruits's Avatar
    Mar 2011
    Quote Originally Posted by Preston67 View Post
    you dont need that bailout gear. you just think you do.
  36. #436
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Quote Originally Posted by bigfruits View Post
    You do not need your 10-42 cassette. You just think you do. 11-40 is enough.
  37. #437
    Jan 2013
    11 - 40.... perfect. Shimano recon its the most successfull gear ratio change yet. The hole thing is about keeping the rhythm. So they say.
  38. #438
    Oct 2012
    I'm convinced that the "rythme" argument from shimano is only a microscopical benefit only valuable for some computerized pro racers. For most professionals and for the rest of the planet its just a marcketing thing.
    The 1x 10-42 cassettes have won serious competitions around the world and they will still be winning in 5 years. But yes, probably in a electrified derailleur version...
  39. #439
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by in-vico View Post
    The 1x 10-42 cassettes have won serious competitions around the world.
    So did 3x7, 1x12-28, 2x11-32, .... What do competitions have to do with gear choice for pretty much all of us?
  40. #440
    Oct 2012
    I talk about competition to explain that the shimano "rythm" concept is a pure performance oriented argument, mostly for marketing purposes. If xx1 and others non-rythme groupsets have won international competitions recently, that means that shimano "rythme" concept is totaly useless for about 99.99999999999...% of us.
  41. #441
    You can take your same argument and insert 1x11
    OG Ripley v2
    Carver 420 TI
  42. #442
    Oct 2012
    Quote Originally Posted by TwoTone View Post
    I dont follow you here. 1x11 offers more realistic advantages than the "rythme" concept:
    -weight
    -reliability
    -quiet riding
    -better mud clearance
    -simpler maintenance
    -ditching the FD makes possible to design 29er frames with shorter chainstays(shortest example known is the honzo with 415mm) for a 26er like manoeuvrability on 29er wheels.
    Well, all that to say that I still think that 1x will remain the most popular choice, even if theire matched derailleurs will probably become electric too.
  43. #443
    Axe
    Axe is offline
    Custom User Title
    -weight
    -reliability
    -quiet riding
    Wut? You do know that you can ride new Shimano 1x11, with just a slighly more narrow range, but the exact same advantages? So how is "Rhythm" affect any of that? In fact, you can ride 1x10 with the same advantages, but cheaper, and with sturdier Shimano derailleur, such as Zee. The only advantage for SRAM is a slightly wider range at the cost of proprietary freehub and expensive cassettes. But it has no option to go 2x11 for even wider range - with a chanring swap and adding shifter/derailler.
    As far as shorter chainstays, it seems that the new side pull FD should address the clearance issues.
  44. #444
    Oct 2012
    Wit the new sram X1, for lots cheaper than xtr you have a ultra wide 1x gearset. There is no match to that anywhere. I'm tired, here its almost 2h a.m. I will follow tomorrow... maybe....
  45. #445
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Two rings up front ain't all bad...
    Some bikes actually climb better in the granny. Some will complain of more pedal feedback, but I'd call it more anti-squat. Many suspension designs give you more of this with the chain angle coming off the granny. It can be a good thing.
    On the 9 speed drive trains front ring shifting under any kind of power was a big no-no. I've now only been on 10 speed a few years and am surprised at how far I can push a front shift under power.
    Dropping a bunch of gears with one click of the FD is nice. I've heard folks overcoming the inherent problem with this on XX1 by going with a Grip shift.
    Tough, steep climbs are best in the granny. Closely spaced gears out back to shift through on tough techie climbs are nice. Also, on extended climbing I find putting it in the granny lets me use much more of the cassette. If I were on a xx1 I think I'd live almost exclusively in the upper half of the cassette.
    The low end is where XX1 seems to be lacking. Especially for 29ers.
    XX1 does seem very appealing. No FD, quiet, lighter, frees up space on the bar for a dropper lever, etc... these are all great things.
    Happily watching the show and waiting until my 10 speed stuff dies.
  46. #446
    -weight
    -reliability
    -quiet riding
    See Devinci Atlas
    OG Ripley v2
    Carver 420 TI
  47. #447
    Jan 2013
    Im currently on XT 11-36. 2x. And I love the dump option. BUT I also feel that the difference between the last 3 cas rings are very noticable. If that transition is better with the 9020 im all over it. I should be getting my set 1st week august. I will feed back.
  48. #448
    You don't pedal up steep mountain trails, you just think you do
  49. #449
    Jan 2013
    Got some 22%. Regular 16 to 18.
  50. #450
    bike tester
    Reputation: syl3's Avatar
    you can dump a lot of gears with gripshift
  51. #451
    Quote Originally Posted by syl3 View Post
    Nope not an option.
    OG Ripley v2
    Carver 420 TI
  52. #452
    Oct 2012
    See Devinci Atlas
    Of course with 430mm chainstays there is some options. See too the Kona Process 111 and the Specialized enduro 29.
    But some 26ers fullsusp. AM bikes have sub 420mm chainstays and still maintaining room for big DH tired(and I dont talk about sub 400mm hardtails). So too drop under 430mm on a 29er you have to ditch the FD. Here is one of the advantages of wide 1x11 gearsets.
  53. #453
    Meh. SRAM 1x11 has basically the same range as my 2x9 32-22 x 11-34. That's good enough for me and allows:
    - solid chain retention
    - tire clearance on a short chainstay 29er (Satori)
    - less weight/stuff on the bars
    - I actually prefer the larger ratio steps of 1x11. I'm usually clicking off two gears at a time with 1x10
    At the same time, I completely understand many would prefer the extra range and finer steps of 2x11. I don't think either one is inherently "better" than the other. I think 1x11 got so much attention because a lot of people were asking for a wide range 1x solution for years.
  54. #454
    Jan 2013
    Ive seen the grip shift work well with the xx1
  55. #455
    So im looking everywhere and theres not a mention of a new hub for the Shimano system...soooo im assuming its just a straight swap of the cassette?
    1 X 11, 1 X 10 10-36... as long as i can fit a fron ring that makes it similar to a Front 26 Rear 36 then i think id be happy...fitting a Sram 1 x 11 to a frame ive got and so ive picked a 30T front for the 42T Rear.
  56. #456
    Oct 2012
    Quote Originally Posted by Andrewfuzzy View Post
    26", 27.5 or 29er?
  57. #457
    26", 27.5 or 29er?
    29er
  58. #458
    lamer
    Reputation: llamma's Avatar
    Does anyone know when the XTR M9000 stuff will be available? Trying to decide if I want to invest in a 40T cog now or wait.
  59. #459
    formerly shabadu
    Nov 2006
    Quote Originally Posted by llamma View Post
    Maybe late September, probably October.
  60. #460
    Well I starting looking into it and Shimano really screwed this one up.
    It has nothing to do with the 11-40 cassette, they are on their 3rd ISpec iteration and of course this one isn't compatible with A or B.
    No fin way I'm buying new brakes to go with this setup and I don't want to go back to 2 clamps.
    OG Ripley v2
    Carver 420 TI
  61. #461
    As the resident expert on this ... do you know the answers to these couple of questions?
    1) Are the last gen shifters still compatible with the new FRONT mechs? i know the rear wont be
    2) Is the cassette a straight swap on the hubs ( unlike sram)?
    My Niner front mech gets sticky with mud and the new mechanicals of the new XTR mech should solve that problem.
  62. #462
    I'm not the resident expert, just called Shimano directly before preordering.
    Cassette fits stock hubs.
    I didn't ask about a old shifter with new FD, call them and ask.
    All I asked about was ISpec 2 working with A or B and the answer was no.
    OG Ripley v2
    Carver 420 TI
  63. #463
    Will the new xtr shifter work with a 10 speed XT derailleur? like the old 8 and 9 speed used to. Or will it be another slight change in the pull ratio so 10 and 11 won't work together.
    Uppo
  64. #464
    Mtc
    Mtc is offline
    Reputation: Mtc's Avatar
    Quote Originally Posted by uppo View Post
    Won't work
  65. #465
    Thanks, I guessed that would be the case.
    Uppo
