Results 1 to 5 of 5
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    Shimano XTR M970 Crankset Clunk
    Was hoping for some insight. When I pedal for a while, and then stand on my pedals as if to go downhill, I get a clunk from my cranks. It is definitely not the pedals as I just replaced them and the problem still exists. It seems weird to me because the crank arm interface should not allow any play.
    I've checked to make sure everything is tight -- done everything short of completely ripping it out and re-installing, which I'll probably do this weekend. Just wondering if anybody happens to be familiar with what's going on.
    Squishy Fishy
    Nov 2008
    What wheels are you running?
    ups and downs
    Sounds like a typical problem with the XTR freehubs and some XT freehubs, I'd also suspect a Shimano rear wheel.
    ಠ_ಠ
    Thanks for the comments fellas. I ripped it out this weekend, cleaned it and replaced it with a proper torque wrench. I guess it must've come loose or perhaps was not installed correctly to begin with as the gap between the crank arm and the bb is significantly tighter now. Seems to be working flawlessly.
    shimano hubs have been doing that for years
