Results 1 to 5 of 5
    Jan 2011
    Shimano XTR drivetrain chain dump
    Recently bought a new hard tail and love the bike, went ahead and got the full XTR setup. 2x10. Occasionally when I hit a bumpy section my chain will dump off the large chainring in between my frame and small chainring. This poses a problem because when I ride rocky trail I dump my chain about every fifteen minutes. I'm not shifting when this happens, just hitting a rough section. Never pedaling either, it usually happens on a rough decent. I really want to race this bike, but if I'm dumping the chain every few minutes I'm out.
    Reputation: bigdrunk's Avatar
    Too many links in the chain? Thats where my money is.
    Reputation: limba's Avatar
    Yeah, maybe the chain is too long. Let's us know when you figure it out.
    bog
    bog is offline
    Are you cross chaining when this is happening?
    What length cage are you running on the rear derailleur?
    Do you know if it is dropping off the top of the chainring or the bottom?
    Could be a few things but I'm with the other guys. Your chain is likely too long. Could also need some adjustment of the B-tension screw on the rear derailleur.
    Tallboy3 CC : Stigmata2 CC : Honzo carbon
    Reputation: DavidR1's Avatar
    Seems strange that it will dump from your large chain ring past your small ring to the frame?? Do you have the correct front derailleur installed? There is a specific front derailleur for a 2X setup.
    I have not had this issue with mine at all FWIW.
    CyclingCentralVa.org
  1. Which chain for SRAM/Shimano drivetrain mix?
    By jabrabu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2011, 12:29 PM
  2. Shimano XT drivetrain and SRAM chain
    By intoflatlines in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2010, 08:08 AM
  3. Shimano 10 speed chain on XTR drivetrain
    By rockyuphill in forum Weight Weenies
    Last Post: 06-16-2009, 09:38 PM
  4. Red Chain for 9 speed Shimano drivetrain?
    By iRoNeTiK in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2009, 12:52 PM
  5. shimano chain on campagnalo drivetrain????
    By dhracer1067 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-02-2006, 06:29 PM
