• 02-16-2012
    duffin
    Shimano XT FC-M785 Crankset 38X26T - 24t possible?
    I am used to 24:36 on my 29er and the new XT drive train with 26:36 is just too hard on loooong steeps.
    Any economical suggestions after dropping big $$ on the new drive train?
  • 02-18-2012
    omega1848
    Sorry I cant help, but I am very much interested in solutions as well.
  • 02-18-2012
    Morewood Shovanist
    Yip I moved to 2x10 Sram 26t/39t chainrings and now no more ultra granny gear :(
    And finding cheap chainrings with non standard ratio's is pretty much mission impossible.
    Sad after forking out for a drivetrain you gotta cough up for 1 chainring that costs over 30% of the price of the whole crankset which incl 2 chainrings!!
    Just imagine the poor chaps with XT cranksets and 28t/40t chainrings , they either always going downhill or have oaktrees for legs
  • 02-18-2012
    ben_stamp
    The xt chainset uses a standard bcd so you can fit a 24t chainring, the only way to do it on the sram chainset is to swap the spider if it is replaceable or unfortunately new cranks.
  • 02-25-2012
    SCR818
    I have the XT FC M785 crankset (26/38 rings) on my 29er and I'm considering dropping to a 24 tooth granny. My XTR FD M985 states that it can switch gears with up to 14 teeth difference in size.
    Is there going to be a noticable loss of smoothness in shifting from the 24 tooth into the 38 tooth chainring (and dropping into the 24 from the 38) if I drop down to the 24 and keep the 38???
    Also is it a 4 hole 64mm BCD chainring that I need in order to do this?
    THANKS!
  • 02-25-2012
    duffin
    Have you tried this yourself? I was told if I drop to it, the shifting performance would be bad.
  • 02-27-2012
    Morewood Shovanist
    THANKS!
    That should shift fine - on a previous bike , using an SLX FD, I was using 22/36 chainrings , which was also a 14 teeth difference and shifting was great. Although that was how the bike was when I got it so I cant comment on whether there will be a noticable loss of smoothness in shifting relative to standard ratios.
    Just be careful to keep the ratio between the chainrings as close as possible to 1.5 , thats the magic number!!
  • 02-27-2012
    duffin
    I'd love to hear from someone who has actually added a 22T to a Shimano XT FC-M785 38X26T and can report experience.
  • 09-06-2012
    TwoHeadsBrewing
    I just picked up a 26/38T XT crankset, moving from a triple Deore crank (24/32/42). I'm hoping the granny isn't too much higher, but if it is I plan on moving my 24T from the Deore over. Has anyone done this with success or failure?
  • 09-06-2012
    IH8MUD
    I have the 2x10 22/34 setup, and it works perfect!! :thumbsup:
  • 09-26-2012
    rick rocket
    I'm currently riding 38, 24 and it works fine.
    Gives you a great range of gears and a similar bottom gear for the steep stuff.
    Big success in my book and Shimano have the XT double specific chainset coming out in the next 2 weeks with that ring setup
  • 09-26-2012
    TwoHeadsBrewing
    After riding the 26/38T, I've found that the range is perfect...no need to put on the 24T for me.
  • 09-29-2012
    Machianera
    BTW shimano makes two different xt 38 rings, one for 38/26, one for 38/24.
    see here: Black Mountain Cycles: 38/26, 38/24 whatever it takes...
  • 11-05-2012
    ybfly
    Beware of the 14t limit: Don't add a 22t chainring to Shimano XT 26x38 2x10
    Hi,
    I bought a used Santa Cruz Tallboy LtC with a full XT setup (stock) and found the Shimano 2x10 (26-38t) setup too steep on the 26t granny (though nice shifting) so I put on a 22t XT front ring (from a 3x10 crankset) after following some of this thread.
    The shifts weren't great, but with adjustment of FD position (down a bit) and limiter screw it wouldn't drop the chain too much. On the stand I couldn't drop the derailleur low enough to eliminate chain drag in the front derailleur cage when in the 22t x smallest 4 rear cogs, but except for the 11/13 I felt the chain was tense enough to avoid problems with the rear derailleur.
    Meanwhile I was worrying about chain slack and tried to check if I could drop a link and still get away with the 22-38t jump on the larger rear gears without overstretching rear derailleur. Since the Big-Big combo is the same, I couldn't change the chain length without overstretching the rear derailleur. So I decided to shift carefully using the small ring only for the steepest technical parts of my rides where I wasn't able to power through on the 26x36 combo while swearing to remember so I wouldn't shift into the small cogs on the back when I was in the small ring in the front. Meanwhile I completed a nice ride and I began searching for a smaller front chainring so I could get it dialed in and drop a few links out of the chain for safety.
    But before I did swap out the front ring and fix the 'chain' slack issue I got a chance to ride Tamarancho yesterday and on a fast right hand bend after the climb and my FD! ghost shifted from 38-22 then my brain froze and I shifted down in the rear to compensate and stomped on the pedals. BAM! The chain likely 'whipped' and popped off the lowest cage roller and sucked into the derailleur cage and flipped the derailleur right into the rear cogs, breaking it in 2! I damaged at least one spoke and bent the nipple on the hose, the cogs in the rear cassette survived but upon inspection I noted a bent inner cog that must have been from the previous owner.
    Based on a thorough reading of everything in this forum and other sites/blogs I broke the '14 tooth' rule (38-22=16!) and with the M785 long cage shadow + rear derailleur being the main casualty.
    I have a few questions: has anyone sourced a good 36 or 34t front chainring REPLACMENT that will fit & work with my XT cranks to swap out the 38t and keep in the 22t?
    If I do finally get a outer chain ring with 36 or 34 teeth, which XT rear derailleur would be most appropriate, long cage or medium?
    Finally, I'm considering a e13 TRS+ dual chain guide when I get everything else dialed in. DO you feel it adds protection beyond a shadow+ rear mech once I fix the front cranks to no longer disobey the 14t rule!
  • 11-07-2012
    DukeNeverwinter
    raceface make great rings. I have some on my xt m770 crank.
  • 11-07-2012
    kwarwick
    How about the 36t ring from the SLX M665 double crankset? Shimano SLX M660 Middle Chainring | Buy Online | ChainReactionCycles.com
    Or you could buy the complete crankset for the rings Shimano SLX M665 Double Chainset | Buy Online | ChainReactionCycles.com and sell the left over crank arms and bottom bracket.
    Karl
  • 11-19-2012
    etanc
    Shimano is going to continue to lose out if they don't match the variety of chainrings that Sram offers. I have only had Shimano on every build but will go 2x10 next time. Going with Sram because of the variety of ring combinations. Hopefully no regrets.
  • 11-26-2012
    Scott In MD
    Karl
    I understand that Shimano 10 and 9 speed crank/chainring spacing is slightly different, so 10and 9 speed components (front shifters especially) are not cross-compatible .... But is this SLX M660 crank actually for 9-speed shifting and chains? If so, I'd like to pick up this crank for a 2x9 hardtail build I'm starting with leftover XT 3x9 shifters, derailleurs, and cassette.
    2x9 set-up on my legacy XT 3x9 shifters with this 36-22 crank x 11-34 cassette should work perfect for my riding.
    Anyone know the answer?
    Thanks.
  • 11-27-2012
    kwarwick
    Thanks.
    The SLX M665 crank I linked to is designed for 9 speed systems so should work fine for your application.
    Karl
  • 12-06-2012
    Kananaskis
    I was told by my guy at my LBS today that Shimano won't make a 22/36 option because it creats to much "torque" on the free hub??? Has anyone else ever heard of this.
  • 12-07-2012
    Scott In MD
    I don't think that is true. Shimano makes a lot of 22 tooth small rings, and matched 36-22 sets.
  • 12-18-2012
    SLR
    Where can you find a 22/36 matched set of shimano chainrings for XT 785 crank arms?
  • 12-19-2012
    Kananaskis
    This is what I've been able to find from Blackspire. You could purchase the Shimano crankset and then fit Blackspire rings. These are 9/10 speed compatible.
    Blackspire Super Pro Inner 2013 | Buy Online | ChainReactionCycles.com
    Blackspire Super Pro Middle Ramped 2013 | Buy Online | ChainReactionCycles.com
    I don't know the quality of shifting with these, but I'm going to try.
  • 12-19-2012
    Scott In MD
    Why not get the Shimano SLX 660 rings in 36 and 22 from C/R? Is the bolt pattern different ? I don't think it us different...
  • 12-19-2012
    Kananaskis
    I think you could do that??? The price is better on the SLX rings anyways...
    It's a shame Shimano doesn't make a XT or XTR 36/22 ring set. Kinda weird.
    Maybe I need to look at the SRAM XO 36/22 with the bash ring. It's a bit lighter then XT.
  • 12-24-2012
    SLR
    Will it work for 10sp?
  • 12-24-2012
    Scott In MD
    The rings will work, but you have to use your crank. Ring spacing is different on 10 and 9 speeds, but tooth profile is same .... .... I think.
  • 02-23-2013
    trailNut_Tom
    I would like to convert my 28/40 M785 to a 22/36.
    Where did you find a 22 tooth ring that would fit the tab designs?
  • 05-18-2013
    mood
    I used a 38-22 setup on my old bike while waiting for a 26y to replace the 22t. It actually worked really well.
    I used the TA Specialites Chinook rings.
  • 08-01-2013
    Rey Recinto
    3 Attachment(s)
    Mine is XT 785 with 38-24 rings....installed with an MRP 2x chain guide
    Attachment 821067[ATTACH=CONFIG]821068
    [/ATTACH]Attachment 821069
  • 08-05-2013
    Morewood Shovanist
    What's the need for a MRP chain guide if you are running a FD?
  • 08-05-2013
    Rey Recinto
    to avoid chain slap...even if I am using the XT RD with clutch...and to avoid chain drops..the MRP 2x I use is 2-chain ring specific...
  • 10-05-2013
    Miker J
    24-36 on a 2x10 would be just about perfect if not a little tall for a 29er.
    I've never understood the push for such tall rings on mountain bikes. If you are spinning out for any length of time on the 36x11 combo I doubt you are mountainbiking.
  • 10-07-2013
    jochribs
    Different strokes for different folks. I run 38/26 XTR's on my hardtail, with an 11-34 XT cassette in the rear. I never leave the 38. Ever. There is climbing involved where I live and ride. On the ride to the trails, the 38/11 gets pretty near spun out, but the 11-34 range is just about perfect on the trails.
  • 10-07-2013
    Idshooter
    Come out west and you'll get out of that 38 real quick.
  • 10-07-2013
    jochribs
    Been out West. Lived in Nevada City, California for a year (really close to Downieville for reference). We're gonna have to agree to disagree on that one.
  • 10-07-2013
    Idshooter
    Don't buy it stud.
  • 10-09-2013
    jochribs
    Don't buy it stud.
    Good for you, and thanks for referring to me as a stud. And what is there not to buy? That I lived in Nevada City? Listen, when I was there, 5 years ago, I rode a 26" hardtail with XTR cranks that had a 36 tooth middle ring, to a 11-32 cassette. I never left the middle ring. There was just no need. Climbs were sustained. On the road, I would generally run a loop that had two 9-11% climbs that were about 4 miles long each. I figured that to be par for the course out there. I really enjoyed climbing them. I had good old regular 53-39 rings run back to 11-25 cassette. I started out pushing that climb averaging about 9 miles per hour. After a handful of times, I was averaging about 11.
    I actually felt like I could have done better and figured most locals to be able to do better than me, but I don't know because I generally rode by myself (with the exception of an also fast younger kid that went to the school that my wife and I went out there for her to teach at. He ended up going to Fort Lewis to race by the way). By your 'not buying it' HS logic, I should have had a triple on my road bike too.
    Just because YOU can't doesn't mean I can't.
  • 10-09-2013
    Idshooter
    9-11% grades are absolutely nothing to brag about. One of my favorite loops climbs 1600 vertical in the final 1.75 miles of the climb. There is no way you are staying in that 38. Seems to me you may not really know what mountain biking really is. Sure on a plush cross country race track the 38 can be done but on a ungroomed steep and technical route you'll need it all. The people on this thread are wanting to know what compatibility issues they may run into not how bad ass you are in your 38.
  • 10-09-2013
    jochribs
    You are scratched. I don't think what you are describing is all that worse than what we have here on the east. It's just longer. When you're done stroking yourself because you're from the west (no offense at all meant to westies in general, just you) you may want to ponder that our climbs are technical and steep here too. The riding is more anaerobic, as opposed to aerobic. I feel aerobic is easier. I think you'd puke if you rode here...or just ride reeeaaalllly slow. You make it sound like we're talking about 40 or 42 tooth chainrings. It's a 38 for goodness sakes....
    Right, so why is it that you have felt the need to chime in dismissively to what I said to MikerJ? I don't see anything that you have contributed either. Glass houses and black tea pots....
    ( No offense was meant to your post MikerJ. For some reason, I get the feeling that you know that. John Wayne over here is another story. )
    Frankly, I get the sense that you couldn't ride in a 38-whatever, anywhere... east or west, hence the reason you had to inform me of what I can't do...you just can't fathom it.
  • 10-09-2013
    jochribs
    Anyway, I'm done here. Wasn't my intent to derail thread. My apologies to the other posters.
  • 10-09-2013
    Idshooter
    Your funny Jersey Shore boy. I'm sure on your bike paths your 38 soots you just fine.
  • 10-10-2013
    jochribs
    :out::smallviolin:
  • 10-13-2013
    TwoTone
    Take your Epeen over to pinkbike, will fit in better there.
