Results 1 to 3 of 3
    Reputation: bikerboyj17's Avatar
    Shimano XT 10 Speed Question
    Can I use the old rear derailleur (M772 XT Shadow SGS Long Cage) along with the new 10 speed shifters and cassette? I believe I can use a 9 speed crank, chain, and front derailleur with the 10 speed set-up right? I'm trying to figure out what I would need to purchase in order to convert to 10 speed.
    ups and downs
    The new MTB 10 speed isn't compatible with old derailleurs. 10 speed road shifters would be compatible with the old derailleurs.
    Oct 2007
    I just found out the hard way that you cannot do this. The dyna sys shifters pull twice as much cable per shift as 9 speed shifters. So it shifts two gears for every one push of the lever. You can use 10 speed flat bar road shifters with a 9 speed rear derailleur though. But the flat bar road shifters cost more than a 10 speed derailleur, so not much point in getting them.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
