Results 1 to 6 of 6
    Shimano matchmaker equivalent?
    Bike is a 2013 Trek Stache with SLX shifters and brakes. I'd like to eliminate the shifter clamp if I can to make room for a dropper post actuator. Does shimano, or someone else offer a matchmaker equivalent? If so, which one do I need and where can they be sourced?
    Reputation: Jrsandiego's Avatar
    Check this out..
    Product
    Hope this helps..
    Feb 2013
    I think it's called I-spec or something like that. You might be able to find the part that converts your shifter pods to mount to the brake levers. I know XT and up has it for sure, not sure about SLX.
    May 2013
    RE: Shimano matchmaker equivalent?
    SM-SL78
    Don't know if they're compatible with your shifter, but I think they are. They will work with your brakes though.
    http://techdocs.shimano.com/media/te...9830747524.pdf
    Sent from my Lumia 920 using Board Express
    Thanks for the links - I'll check that out.
    Reputation: PerthMTB's Avatar
    SL-78 converter only works for XT, doesn't work for SLX shifters, you'd need to buy new SLX I-Spec shifters.
  1. Matchmaker for Avid Elixir/Juicy & Shimano shifters w/pic
    By euskafreez in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-22-2013, 04:37 PM
  2. Hope Matchmaker and Shimano i-Spec
    By 007 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2012, 05:06 PM
  3. matchmaker
    By ehigh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2012, 08:02 AM
  4. Matchmaker X
    By ArcticCat500 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 06:04 AM
  5. XTR matchmaker
    By ongxw2005 in forum Shimano
    Last Post: 03-16-2011, 08:15 PM
