Results 1 to 6 of 6
    Reputation: Highwaystreets's Avatar
    Shimano M810 Saint Brake Help
    So i've decided to put these brakes on my bike but have a couple of questions first.
    First can i run the Shimano 180mm rotors with them or do you have to go 203mm? i think the 2013 Saints were only 203mm but don't know if that is true with the 810 group.
    Second can you use Avid 185mm rotors with them?
    Thanks Guys!
    Current Rides:
    Trek Stache
    Anyone? i bought the levers today so just need the calipers now.....
    Current Rides:
    Trek Stache
    Apr 2005
    The only thing that would limit your rotor size is your frame and fork. For example with a Fox40, you have to run 203s.
    Quote Originally Posted by epic View Post
    i'm putting it on a fox TALAS 32.... so if i just run the 180mm rotor adapter then it should be good to go?
    Current Rides:
    Trek Stache
    Apr 2005
    yep
    awesome.... just need to find the calipers now....
    Current Rides:
    Trek Stache
