are there any compatible (power links) known for the Dyna-sys 10 speed system? I'm not a big fan of the connector pins that much. I like taking the chain off regularly to clean.
You are aware that doing deep cleaning on chains strips the factory lube out of the inside? You end up with a pretty chain (for a while) that will wear out faster.
+1 for KMC links, but I find them a bit stiffer than the 9 speed versions (tighter tolerances perhaps?) so recommend investing in a pair of link pliers as well to ease the removal process.
I second Perth on the Park link pliers. I have them and use them regularly on the KMC missing link. Makes it very simple.
I also cut a wire hanger and bent the ends down and inward making hooked ends. I then place this through the chain links to hold the tension off the chain. Makes removing and replacing the link much easier.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
