Results 1 to 2 of 2
    Dirt Rag Extraordinaire
    Reputation: m0ngy's Avatar
    Dec 2005
    Saint M805 BB compatibility
    Is the Saint M805 bottom bracket compatible with an M810 crankset?
    It should be, but I'm not 100% sure.
    Also, are M805 or M810 chainrings compatible with a 10 speed chain?
    I believe they are, but again, I'm not totally sure.
    No problems changing between top and bottom chainring with a 10 speed front derailluer?
    Thanks for your help.
    "You go up the hill, you go down the hill."
    Apr 2005
    Pretty sure that the 5 on 805 denotes 83mm BB shell same on 815 - 825 and so on, so M805 won't be a direct fit. The sleeve in the middle will probably be too long. Your chainrings will work with 10 spd chain but might be a bit less then perfect. The narrower chain could have a little more challenge getting from one ring to the next or could get stuck in between.
