Results 1 to 3 of 3
    If you think you can
    Reputation: 62kona's Avatar
    Saint front hub nightmare!
    This hub has been rolling great for the past few years, but my rear needed a rebuild so I had them take the front apart while they were at it and re-grease it. There are specific tools needed to properly re-install the bearing cups and get all the play out, but the shop that rebuilt it said the play cant be taken out. "Its in the design". Bull ****! I've called several other shops since then and no body caries these shimano specific tools.
    Any body else run into this problem? I almost just want to order the tools myself, or just buy a different hub. But then comes new spokes and a wheel rebuild which I didn't want to have to get into just because of some hub play.
    Reputation: Wombat's Avatar
    If you have the M800s they're certainly different to other Shimano hubs that I've seen. If you want to get the tools yourself, try here: http://www.cheapbikeparts360.com/pro...int-hub-tools/
    The shimano tech site has an exploded view of the hub and tools: http://techdocs.shimano.com/media/te...9830611824.pdf
    Tim
    Thanks tim. I was thinking about just doing that. Would save me gas from running around to all these different shops.
