Results 1 to 10 of 10
    May 2013
    Repairing the Wife's Bike- Tourney TY-30 Crankset Question
    First off thank you to the owners and posters here for the website. I spent weeks combing through the wealth of information in the reviews as I shopped for my new/ used bike on Craig's List. I've learned when you don't know go to people who do and educate yourself.
    I'm pretty mechanical (replace most of my own truck parts and turn wrenches on a few race cars when i can) but don't have any real bicycle experience. The second (center) crank gear on my wife's 1999 Diamondback Wildwood is bent and broken. Its decent old bike but she hasn't riden it in a couple years and wants to get it fixed so she can.Rather than dropping it off at the LBS I decided to use the opportunity to fix it myself and learn something. I bought a bicycle tool kit today and pulled the crank and gear off my old off my junked Mongoose to swap the gear set out. I learned lesson #1- the gear set and crank arm are made together and apparently don't come apart.
    I go online and Bikipedia says its hers is a Shimano Ty-30 w/ 170mm crank arms and that appears correct. I shopped a few minutes and several sites say it's unavailable. Amazon doesn't list it.
    So I suppose my questions are 1. Does the gear set come apart from the crank arm and I'm missing something? 2. If it doesn't what is a replacement that will bolt up for a decent old bike that doesn't get much riding so I don't want to spend much on it? Thanks and I look forward to the conversation and will try to contribute around here where I can.
    Reputation: Aresab's Avatar
    On very cheap cranks, the chainrings are riveted and when shot, you replace the whole assembly. If I recall, the TY-30 is a square taper (bottom bracket bearings/shaft) so cranks of this type will work, you just need to look at the chainring setup and match that so you don't have to change front derailleur or chain length. Examples are, 24/32/42 or 28/38/48 and refer to the number of teeth per ring. The link below has 24/32/42 cranks that should work fine, they also have other version if you look around the site.
    Shimano Tourney FC-M131 Crankset 170mm - AAWYEAH Bikes and Bicycle Parts
    May 2013
    Thanks RSabarese for the reply. I have one on the way.
    Apr 2005
    I'm just wondering what bent/broken means. On the center chainring there are teeth that will appear to be bent and/or clipped out. They are supposed to be that way in order to enable better front shifting.
    May 2013
    Quote Originally Posted by epic View Post
    Its bent for sure. I'm not having any luck uploading the picture to the forum here though. There are four different cracks in the teeth of the gear. Is that normal?
    May 2013
    nm
    Repairing the Wife's Bike- Tourney TY-30 Crankset Question-img_20130530_100930-copy.jpg
    Is it suposed to look like this? Maybe it is.
    Repairing the Wife's Bike- Tourney TY-30 Crankset Question-img_20130530_100946.jpg
    ups and downs
    No, that is a dead crankset, it shouldn't look like that.
    Apr 2005
    The bend is no good, the cracks are on purpose.
    Jun 2012
    On purpose? I know some cheap cranks have problems similar to that right out of the box, but that is wrong. A rock or something must of got it.
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by aBicycle View Post
    epic is correct. I've you've ever seen one of the really cheap Shimano cranksets, where the chainrings are are stamped steel, the shifting "ramps" actually end as hangnail like sections of chainring that appear to be broken. Back in my shop days, lots of folks thought that their new bikes had defective parts, but in typical Shimano fashion, they actually shift pretty well when new. In the picture above, rust has caused the paint to lift, which makes it look even worse. As rock mentioned, that crank is toast.
    -D
  1. Cutting weight on wife's bike (5' 105lbs)
    By Livingston in forum Wheels and Tires
    Last Post: 03-23-2014, 05:20 AM
  2. Recommend me a fork for my wife's bike
    By medimond in forum Shocks and Suspension
    Last Post: 10-23-2012, 09:22 PM
  3. Help choosing groupset during wife's bike build
    By hadique in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2012, 09:36 PM
  4. Altus shifter compatibilty with Tourney RD
    By Basser in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2012, 10:38 AM
  5. My wife's bike has bars that are 28 inches wide...
    By Mountain916 in forum Beginner's Corner
    Last Post: 05-22-2012, 02:52 PM
