Results 1 to 5 of 5
    Remove Shimano Freewheel
    I have an FH M755 XT hub and the freewheel body is making a horrible noise.
    I have looked at the exploded view at the technical documents at shimano;
    http://techdocs.shimano.com/media/te...9830611910.pdf
    It looks like I can take it apart. Does anyone have experience with this?
    It looks like I remove a sleeve in the hub. What tool do I need for this?
    Thanks for any help
    ups and downs
    Park Tools has the instructions
    http://www.parktool.com/repair/readhowto.asp?id=45
    You need a long 10mm allen wrench to break the body fixing bolt (15) loose, plus all the standard cup/cone tools.
    It's a 14mm wrench for other hubs, is this one different?
    ups and downs
    Older Shimano hubs with the 10mm axles are 10mm Allen keys.
    http://sheldonbrown.com/k7.html#transplant
    Reputation: socal_jack's Avatar
    Dec 2008
    You probably broke one of the pawls, these POS Shimano hubs seem to do it real frequently, went thru the same thing with mine. Just order a freehub body now and save some time.
