Results 1 to 9 of 9
    Proud bike-o-holic
    Reputation: Psycho Marco's Avatar
    Nov 2008
    Question about XTR crank installation
    Hello all,
    I have a XTR crankset installed in my current bike which has 73mm bottom bracket width. Iīm thinking about buying another frame which has a 68mm BB width.
    My question is: Do I need to do or buy something in order to install the crank in the new frame?? Someone told me I need some spacers, but I donīt know where to buy them.
    Regards
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    You'll need to add a 2.5mm spacer on each side.
    External BB XTR, old Octalink or Square Taper BB? If it's a square taper XTR, then you need a new BB for 68mm shell. Also if it is square, do check the BB spindle length as there are shorter ones out there.
    ups and downs
    Most any bike shop should have a huge box of spare spacers.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by oldskoolbiker
    For a standard 68mm shell you will need 2 2.5mm spacers on the Drive side and 1 on the Non-Drive side.
    Attached Thumbnails Attached Thumbnails Question about XTR crank installation-picture-1.png
    Proud bike-o-holic
    Nov 2008
    Ok, thanks all for your support.
    I will order them ASAP.
    regards
    A Mountainside=My Therapy
    Reputation: ColoMtb20's Avatar
    Is that installation diagram just for the xtr? my gxp bb runs without any spacers on a 73 mm. Is there a problem?
    ups and downs
    No it's Shimano only, SRAM/Truvativ have a different approach that make them unfriendly to e-type derailleurs and BB mount chainguides
    Ok thanks for the info. That's what I was hoping to hear.
